SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
SOURCE: relay clicks, gas blows, rollers dont turn
If you use it regularly, the liner should be replaced about every 6 months. Make sure you get a wiper for the wire. It goes inside the machine, on the wire, just before the feed rollers. It keeps the dust from clogging the liner.
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Follow this Link:
http://www.clarkeservice.co.uk/manuals/mig_welders/migpro90_150te.pdf
Let us know if it was the right one.
SOURCE: Mig gas conversion for JobSmart 125 Flux Wire Welder
The other difference between gas/gasless is the ability to reverse the gun polarity which you can't do with a gasless only welder. You can get it to work but not safely and reliability could be an issue also.
