Question about Science & Laboratory
I have an error on my euronda E5 the error code is E48
  • 18,127 Answers
That is an autoclave and peoples life and health depend on it. Please contact the manufacturer at +39 0445 329811
Posted on Sep 27, 2019
2 Suggested Answers
6ya staff
SOURCE:
clifford224
Clifford Beard
  • 1975 Answers
SOURCE: what does an e48 code mean on 1990 cadillac
Below os a description of what code e48 is and basically has to do with the EGR system and your computer doing tests and the tests failing. As far as the other codes I'm not certain to be honest with you. I do know by holding the "OFF" & "LOW" buttons at the same time clears the codes in the BCM and a 7.0 should appear at the end. The .0.7 and the .8.8.8 I am sorry but didn't have any luck with that and really haven't heard of. Wish I could be more help but here is the description on the e48 for you. Hope this helps.
Posted on Mar 14, 2012
Hello, does anyone recognize E61 error code for Euronda E9 autoclave please?
The error E61 indicates that your water pump has failed or is not active. You should check the pump and replace it if needed. You should also check the steam generator sensor and replace it if needed.
For more information, contact Euronda at Water inlet pump inactive or call (+39) 0445 329811 (Vicenza, Italy)
Jan 08, 2018 | Science & Laboratory
What does an E5 code mean?
Make and model helps, but here are all the E5 Error Codes we get asked.
On a cellphone?
E5 code Google Search
On a washing machine
e5 error code code washing machines Google Search
Dishwasher
e5 error code code dishwasher Google Search
Stove / Cooker
e5 error code code stoves Google Search
Fridge
samsung fridge e5 error code Google Search
Aug 27, 2017 | Cell Phones
My ATF6000ES Front Loading washer runs on any cycle for about 5 minutes then stops, and the display resets to the start and nothing more happens. Got an E48 code and ran "test 7" and the tub did not
Hello Nick Jensen, thanks for your post!
From what you have described your Frigidaire washer is displaying an error code of "E48" and you have changed the control board with the problem continuing to be present. An "E48" error code could be a possible problem with your door lock assembly, motor control board, or control panel. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. I hope this is helpful. -Matt
Jan 30, 2015 | Frigidaire Affinity ATF6000F Front Load...
Errors in euronda autoclave
http://www.euronda.com/contacts.aspx
Feb 10, 2014 | Science & Laboratory
7 whenI have autoclave Euronda E switch on , an error say no power supply ... any solution please ?
See if voltage is available to the unit. If so,. Replace the power supply within the unit itself.
Dec 08, 2013 | Science & Laboratory
Errors in euronda e5 autoclave
What is the alarm?
What phase of the cycle are you getting your alarm?
Oct 31, 2013 | Science & Laboratory
Code E48 what part do I need
Good Morning Gerald, thank you for your question!
If you are getting an error code E48, it usually means that the board thinks the door PTC (positive temperature coefficient) circuit is closed. This particular part is the wax motor on the door lock. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards!
Sep 06, 2013 | Frigidaire Affinity ATF8000FE
What does an e48 code mean on 1990 cadillac
Mar 14, 2012 | 1991 Cadillac DeVille
Frigidaire Affinity ATF8000FS gives me an error code of E48. Stops a few mins after cycle begins
I have the same code and problem...E48:Board thinks the PTC circuit is closed. Any help?
Jul 24, 2010 | Frigidaire Affinity ATF8000FS
I'm getting the blinking locked door light and error code e48
e48 SAYS THAT THE MACHINE DETECTS THAT THE DOOR IS NOT LOCKED.UNPLUG MACHINE FOR 30 MINUTES TO SEE IF IT WILL RESET.iF PROBLEM PERSISTS,YOU MAY NEED A DOOR SWITCH
Nov 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Science & Laboratory Logo
83 people viewed this question
Top Science & Laboratory Experts
Pokinhas
Tom Chichester
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
