SOURCE: What is m2 code how cani reset in Konica Minolta
This is to display the count of the supplies life counter.
When the counter is reached to 0 life 1 will be detected and maintenance call M2 will be appeared.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
- To clear the count, use [CLEAR DATA] of the Service Mode.
SOURCE: konica minolta bizhub 164 showing M2 maintanaince call
You need to replace 1st the consumables before simulation/reset to prevent further damage to Bizhub 164.
SOURCE: konica minolta bizub 164 call service c3451 tell how solve
Warming-up failure
1 Check the fusing unit for correct installation. 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 5 Change PRCB. 6 Change DCPU.
