Question about Ryobi Garden
Does both gas lines in the Ryobi bp42 have to be immersed in the gas tank? or does the one without the filter remain above of the gas?
    Loyalty:
    Visited the website for 30 consecutive days.
  • Ryobi Master
  • 363 Answers
This is just the return to tank pipe, it does not need to be in the fuel, just in the tank far enough not to leak out the top.
Posted on Sep 25, 2019
Testimonial: "Thank you for your prompt response, will cut it so it's not in the fuel."
    New Friend:
  • 18 Answers
Remain above the gas
Posted on Sep 27, 2019
6ya staff
SOURCE:
Anonymous
  • 155 Answers
SOURCE: GAS LINE PROBLEM
Hi this is the way it should go: 1 from the filter in the tank to the bottom of the carby,2 from the top of the carby to the inlet on the primer,3 from the outlet on the primer back to the tank as this is the return line nothing goes onto it.
Posted on Aug 04, 2009
Mike Carew
  • 969 Answers
SOURCE: ryobi 700r gas trimmer, replace old fuel lines
1-800-345-8745 US
1-800-265-6778 Canada
Posted on Aug 23, 2009
rustysheriff
Tony Groves
  • 344 Answers
SOURCE: gas lines on ryobi cultivator
Exploded view:-
http://www.outdoordistributors.com/pdf/Ryobi/RYOBI-410.pdf
Did you replace the gasket (item 15 on the linked document) when replacing tank and lines, if you didn't and the old one has been torn it could be sucking in air, also the 4 carb mount screws need to be of equal tightness
Posted on Apr 23, 2010
Anonymous
SOURCE: where do I connect the fuel lines on my ryobi weedeater?
I have Ryobi775r string trimmer with walbro WT526 carb. The fuel lines connect 3 parts eg. gas tank, bulb (mine is a separate bulb not part of carb.) and the carb. The bulb has 2 fittings- a short and a long one. The carb also has 2 fittings- one on top (vertcle) and one on the bottom (L shape). The gas tank has two holes in the bottom one for over flow line and the other for fuel inlet to the carb. This has a filter in the gas tank. Now the connections- connect the long fitting on bulb to the tank. this is the overflow. Connect the short fittin on bulb to the carb top (verticle) fitting. Connect the fuel line (with filter - it is in the tank) streight to the L fitting on the bottom of the carb. Make sure the fuel lines are of right diameter. Too big-and you will have leaks. You are done connecting the fuel lines. just for info. the bulb is there just to pull a vavcume in carb so that the fuel is sucked into the carb and is present there when you start the engine. Hope it helps. Good luck.
Posted on May 10, 2010
Anonymous
SOURCE: How do you get the fuel line connected to the fuel
You must run the fuel line through the back of the tank and out the filler hole,make your connections,i used a small amount of vaseline to make the connections.Then pull the filter into place,make sure some of the nipple of the filter pokes through,then slide the retainer ring on the hose and force it onto the filter nipple.
Posted on May 15, 2010
My Ryobi BP42 wouldn't start, I noticed that the fuel hose detached from the carb, I re-seated it and it worked great. The next time I used it, it starts no problem, but idles 1 sec then stalls.
hi
the fuel filler cap it has a small hole ( about 1 diameter )
if this hole gets blocked it creates vacuum within the fuel tank stopping fuel flowing into the system
Dec 28, 2017 | Ryobi Garden
Ryobi bp42 leaf blower won't start got gas got compression an got spark a light spark? Help
if by chance it was ever run without the proper amount of oil in the gas then the cylinder walls are scored too bad and it will never run . has to have the proper compression
Aug 07, 2015 | Ryobi Garden
Ryobi BP42 leaf blower will start but will not rev up when I push the trigger - how can I fix this?
Its a lean condition, not getting enough fuel. Check fuel filter and fuel lines. be sure you have fresh fuel. and the carb needs to be adjusted or rebuilt.
Jul 08, 2014 | Ryobi Garden
My Homelite d3300 DX series runs great for a while then quits some say its a stopped up but it looks clean some say air filter it is clean do you have any solutions I mixed gas ratio 40:1
Hal:
Check the fuel filter at the end of the fuel line in the tank... sometimes it will get hung up in the tank and won't be immersed in the gas. also check to see if there is enough fuel line in the tank to ensure that the fuel filter stays immersed in the fuel in the tank.
Jan 02, 2013 | Garden
I have a ryobi #790r the gas lines were bad , in replacing them I find an extra hole in the gas tank I can't figure out what came out of it, I found nothing that would indicate something was missing ...
The best way to state my solution is to give you the instructions I made for just replacing the bad fuel lines on a 2-stroke trimmer. Your Ryobi should fit this bill.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
May 14, 2011 | Garden
I need the fuel/oil mixture for Ryobi 31cc 775r gas weedeater. Also the diaphram for the fuel line replacement.
The fuel/oil mixture is 40:1. That is 3.2 oz. oil/US gallon. Now for the fuel lines:
Jan 09, 2011 | Ryobi Garden
Hi, I have a ryobi BC30 brush cutter my fuel lines inside my fuel tank broke so I don't know which one go where right now the filter plugs into the bottom of carb and return and another short hose go to...
Nov 06, 2010 | Ryobi Garden
I have a Ryobi 700r trimmer - I needs a diagram of all the fuel line hookups
<div id="ms__id6" class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.<br />If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.</span> </div><!-- from fixya rte -->
Aug 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My ryobi grass trimmer will only run on 1/2 choke model RY 30524
Check for fuel supply problems (clogged cap vent, dirty tank fuel filter, clogged or faulty fuel intake lines, leaky or cracked primer bulb, air leak in rear crankcase cover...check 4 screws above gas tank, air leak in carb gasket...check carb nuts, trashed up carburetor...needs cleaning or rebuild, mixture screws need adjusting)....a myriad of possibilities here but I would guess it's a dirty carb....hope it helps
Jun 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Lenght and position for Ryobi RY08548 Blower fuel line in gastank
take off the fuel filter and see if that works . if it runs then it needs a new fuel filter. keep me posted
Apr 11, 2009 | Garden
Garden Logo
82 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Dennis Tokarzewski
Level 1 Expert
Wayne McNeil
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
