Water heater stopped working a few days ago. Checked breakers, wires, connections, plumbing.
Troubleshoot and numerous illustrations of tank and wiring appear on following links:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
http://waterheatertimer.org/How-to-convert-energy-smart-water-heater-to-ordinary-water-heater.html
I
SOURCE: my water heater is making my electic meter spin like mad
Hi Is this powerstar AE115 a tankless water heater? I suspect the 115 designator in the model number means it runs on 115 volts. And what is the second Tank ? Storage or an electric water heater? Both should be rapped with insulation to hold the heat. Meaning storage or electric water. Don't rap a tankless water heater. At the very least get a licensed electricen in to make sure you electrical service will support a 240 volt system. If it can , do it. Think of electricity as a river flowing. Volts are the speed the water flows. Amps are the force ( Also caled Impedeance) that push the water.( And spin your meter like a top I might add.) And resistance as how many bolders, Rocks, Old fords that are in the river bed slowing down the flow of water.Now here is where OMES LAW comes in. E= I x R. (E) volts is equel to the (I) impedeance (Amps) multiplied by the ( R) resistance. You can spin this in a clockwise direction and find the net value by dividing one from the other to get the net. ( I = R * E ) If This is true ( and it is ) if we double the voltage (current) we can realise a reduction on the Impedeance (Amps) of up to 1/2 of its current value.In other words if you were useing 100 amps @115v you will use 50 amps @240v Depending on the resistance. Sorry but I forget the voltage drop on 100 feet of copper wire but I assure you its real low.But your best bet would be to use a tankless water heater core in you boiler that you use for heat if you got one and save the electric for summer mode.
SOURCE: Kenmore Electric Water Heater/ Economizer 6
it usaly takes a few hours to heat up depending on water size check our breaker to see if it tripped out make sure all your wire connections are good u could take the front plate off and hit reset if you dont get hot water in a few hours ull probibly have to replace the trermostats and maby the elements its not hard to do good luck
SOURCE: when hot water is turned on the pipes make this vibrating sound.
A rumbling more than a vibration? If one in the same, the heating elements may have calcium build up which causes perculation like the perculator coffee pot which causes the heater to vibrate or rumble. If the elements can be removed they can be cleaned by soaking in lime away or a descaling solution. All said and done it will work like new.
SOURCE: I need to know the breaker size and wire gauge and
According to the user manual below, it's a 50 amp heater, therefore, you need 6 AWG electrical cable and a 50 amp double pole (220 volt) breaker in the main service panel.
You need two hot wires and a ground wire. The cable would be specified as 6/2 w/ ground. The 2 hot wires in the cable would be red & black or black & black -- these attach to L1 & L2 respectively. ( L = Line )
More info, let me know.
Charlie
http://ecx.images-amazon.com/images/I/A1b%2BxE2vITS.pdf
SOURCE: I have a GE hot water heater, SE40M12AA01, dual
1) You posted under Rheem-GE electric water heater.
If upper element is burned out, then water heater will not heat any water.
http://waterheatertimer.org/How-it-works.html
2) Replace upper element:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) Open following link for complete troubleshoot:
This troubleshoot assumes you have standard thermostats and elements.
4) Manuals and links. I do not see 'smart lights' in the manual.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Standard_Water_Heaters
Troubleshooting starts page 15.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=AP12168-7%20%28GE%20Elec%29.pdf
5) Add a comment with your experience so other with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
