Question about LG Refrigerators
Have a LG refrigerator model#lfc207405T and its making a grinding sound like a loose fan checked the condenser fan on the back bottom and it is not it coming from higher up. Is there another fan.
  • LG Master
  • 4,656 Answers
It could be your evaporator fan that's located in the back of your freezer being blocked by ice buildup. you will have to turn off the light by either using a magnet or pressing the light switch off so fan will run while door is open. Fan will not run while door is open and light on. Do you have frost buildup on rear wall of the freezer?
Posted on Sep 26, 2019
  • John Tripp
    John Tripp Sep 26, 2019
    Your model is the LFC20740ST00r the last two numbers may be differenthttps://www.searspartsdirect.com/model/6...
6ya staff
SOURCE:
Amigaman
Gerald Griffin
  • 248 Answers
SOURCE: ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Posted on Nov 14, 2007
Robert Hirst
  • 833 Answers
SOURCE: LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Posted on Jan 10, 2008
Anonymous
SOURCE: lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Posted on Jul 12, 2009
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: the refrigerator makes a popping sound
sounds like it's your self-defrost working normally as for things freezing,check temps in front and back of refrig and you may be able to raise temp to alleviate condition w/o food in frt end being too warm
Posted on Aug 23, 2009
Testimonial: "thank you As a matter-of-fact, I did try raising the temp and the popping did stop now I am going to buy a thermometer for the frig and freezer "
Anonymous
  • 64 Answers
SOURCE: LG dishwasher is making loud grinding sounds
debris in pump. unplug and disassemble pump. clean out and reassemble
Posted on Aug 26, 2009
Condenser fan noise
you should have warranty from the tech at least one month ,but it sounds like motor fan is giving up umplug your fridge take off back bottm part to expose the fan and condenser clean all the lint in the condenser vaccum is better ,turn fan with your finger it should be very loose ant turn freely if it stucks its the motor ,umplug the motor pull the fan with the plastic base out of its place,take off the screw on the fan,pull and twist it by hand,take off two or three screws that is holding the motor to de base, buy a newone ,a the apliances store or online for about 45.00 put back everything in reverse way.plug your fridge, enjoy!!! good luck
Apr 07, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Bottom freezer model GB18DKXJW00 looses its cool. If allowed to rest (1/2 hour) it will resume cooling (-10C) and then repeats
First check the condenser coils to see if they are dirty, these will be at the bottom in front or back. You will have to remove the cover. Make sure both fans are running, 1 in freezer other in back with compressor
Mar 24, 2011 | Whirlpool Refrigerators
I have a lg frige model #lrbn20512ww. it quit cooling both upper and lower yesterday. are there any known problem with the compressor or could it be somthing else. the compresor runs for about min the...
unplug the ref remove the back panel place a fan behind the ref to cool the compressor when you can place your hand on the compressor then you can clean the condenser coil and plug it back up make sure the condenser fan motor is running
Nov 18, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
I have LG Bottom Freezer Refrigerator for 5 years. I noticed that yesterday that a funny motor sound came from the back of the refrigerator. When I open the refrigerator or freezer door, the sound would...
The problem could be a bad bearing in the condenser or evaporator fans...more likely though is that the evaporator fan is hitting an ice build up on the coils...this can be caused by a bad defrost timer...
more closely check on the sound... you will find it....
a few drops of oil on the fan shafts just ahead of the motor will not hurt either...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | LG LRDC22744 Bottom Freezer Refrigerator
Loud noise under refrigerator
it's a condenser fan, it's located on the bottom ,,at the back of the frig
unplug it first from the wall, & vaccum under neath bottom & around the fan,,then you need to see if the fan came loose from the shaft & if so tighten & also make sure nothing is caught in the fan...
Aug 01, 2010 | Whirlpool ES5FHAXS Side by Side...
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
3 ton air conditioner {1 yr. old } has rattle
check tightness of grill on outside of condenser,then push on different areas of the unit to see if sound changes or quits,also check all screws etc. & make sure they're all tight,is so it could be fan condenser motor bearings bad fan loose on shaft
Aug 27, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Apr 17, 2009 | LG LFX25960ST Stainless Steel French Door...
Whirlpool Fridge Making a rattling noise
There are 2 areas it could be in....The upper area where the evaporator fan is....or the lower area where the condenser fan is..
If it is in the freezer...when you open the door there should be a button that the door connects with that you can hold in manually to make the fan engage..and listen for the noise..the odds are if it were ice build up....your thumping the fridge would not make it stop ..since the thumping would not remove the Ice...it would continue to build up and the fan would eventually stop completely and everything would warm up. It could be a loose stap that holds evaporator lines in place or a motor mount that is loose ..
Or it could have to do with the condenser fan..where the compressor is.The compressor and condenser coil are located underneath the freezer section of your refrigerator. There is some tubing connecting the compressor to the condenser coil. There is also a condenser fan to cool the condenser. To access these parts the refrigerator has to be pulled away from the wall. If you pull the refrigerator out go slowly and watch the tubing that connects from the water valve on the back of the refrigerator to the water cut off at the wall.
Remove the power from the refrigerator. Remove the lower panel on the rear of the refrigerator. Look inside for anything loose. Locate the condenser fan motor and blade. These are the areas to stay away from when power is applied. Plug the refrigerator back in being careful to avoid the condenser fan motor and blade. Wear gloves to prevent burning yourself on the hot refrigerant lines and try touching tubing and lightly pushing and pulling to see if you can cause or stop the noise.
Generally a rattle or hum is caused by a refrigerant line touching part of the cabinet or base pan. If it is not repaired it may rub a hole in the refrigerant line causing the refrigerant to leak out. If you don't feel comfortable trying to correct it, you should schedule service and let a technician repair the refrigerator.
I hope this helps...please rate me ...thanks The Fang
Mar 26, 2009 | Refrigerators
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
Refrigerators Logo
169 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
