Water Filters & Coolers Logo
j
joe rundell Posted on Sep 25, 2019
My Hamilton Beach water cooler does not cool the water, is there an adjustment where I can turn up the compressor to cool the water it seems for the compressor just keeps running never shuts off and the water does not get cold .
Hamilton Beach Bl-1-3 water cooler
You are my 40,000 question that I have answered! You don't get a prize, but I think that is pretty neat Paul :>D I have been here a long time.
The manual only says that you have to make sure that cooling is switched on (Page 12). The unit has a 1 year warranty. If it out of warranty, you just need to pick it up and take it to a refrigeration engineer. It may need topping up with refrigerant gas.
Consumer Support Questions?
How to contact us:
Telephone 800-488-5080 (Monday - Friday 8:00AM-5:00 PM ET) E-mail: [email protected] [email protected]
https://useandcares.hamiltonbeach.com/files/840178600.pdf
There are some videos here that might be of interest.
https://www.google.com/search?q=Hamilton+Beach+Bl-1-3+water+cooler+not+cooling+the+water
Hope the information helps you.
Our Hamilton beach water cooler makes a constant noise as it cools the water. The cooler does not shut off once the water is cold. Series #A0370CT.
When empty of water remove the back panel and the cooling fins are most likely covered with an inch of dirt! Find an air compressor and blow out the dirt. It worked on mine!
Cooling unit does not shut off
Replace Thermostat and find the model number, Sea Breeze
Hamilton Beach Water Cooler Model 2202 cold water does not get cold. How can I fix the problem
No Cold Water
Hi. I have a Hamilton Beach Model 2202 and it's been working fine until last week. Now I have no cold water.
3helpful
Hamilton Beach water cooler dysfunction.
Check to see if the dispenser has an integral water filter. If yes, replace it to improve the taste of the water. If no, then unplug and remove the top panel and shut off the water supply line to the unit.
You'll want to drain the cooling tank and clean it with some white vinegar to remove any mineral deposits that could be affecting the taste of the water. You'll want to lightly scrub the inside of the chilling/cooling tank with a mixture of at least 2/3 white vinegar and warm water to help dissolve any residue in the tank.
After you've gotten it as clean as possible, turn on the water supply line and flush the tank by filling a pitcher from the cold water dispenser. Do this for at least 2-3 gallons of water to completely clear out the vinegar mixture.
You'll also want to remove and sanitize the dispenser valves on the front of the unit, as there could be some gunk inside the spout that is adding to the foul taste and odor.
I would also suggest you install an inline charcoal water filter to the supply line serving this cooler, as that will only help improve the taste and clarity of your drinking water.
You should be able to adjust the temp of the cold water with a thermostat controler located inside the cabinent. You might want to contat Hamilton Beach to obtain an owner's manual for your unit to get more detailed information about use and operation recommendations.
Hope you found this info very helpful and best regards!
4helpful
Hamilton beach water cooler is not cooling
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing. A little oil inside the motor and several revolutions later might get some relief until a new motor is installed.
10helpful
2answers
No Cold Water
3helpful
Won't Stop Cooling
thermostat is stuck. try buying a water cooler control from a local supply house.
Top Water Filters & Coolers Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
