The auto defrost is not working in the freezer, and frost is building up on the things stored in there. The food in the refrigerator section is cool, but not cold, and things are going bad before they should. I made sure that nothing was impeding the air flow out of the vents and it was better for a day or two, but it's back to its old tricks.
You are going to have to completely defrost the freezer and that includes removing the rear panel inside and clearing the coils. You will also have to determine what component in the defrost circuit is bad and replace. I would also look for a air leak around the gaskets as frost is a sign of warm air infiltration.
Eric
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
SOURCE: Frigidaire #FRS26ZSH : Fresh food not even cool.
that is a defrost problem need tech to one of a few possible problems you can defrost unit completely for 2 days and it will work great for a week or so
SOURCE: Frost buildup
you need to check the defrost circuit and make sure the heater is working and the unit goes into the defrost mode.
also check and make sure the temp sensor is good
SOURCE: Frost Buildup in Frost Free unit.
You will have to check the defrost timer to make sure it is turning if it is working properly and you are getting power to the defrost heating element below the freezer coil it should get hot if you have a 115volts or so to the element and it does not get hot then you have a bad element
SOURCE: Miela fridge freezer freezes food in the fridge
Most likely reason is fridge evaporator sensor faulty. The sensor is screwed to the back wall of the fridge behind bracket next to light and has a green band near the end . The sensor come as a repair kit (part no. 7323301). Just follow instructions in the packet.It is quite straight forward
