The memory card is okay and new batteries won't work. The camera will beep and that's it
Https://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s4200-s4500_manual_en.pdf
Page 109 of the manual lists possible causes such as battery chamber not latched, batteries not in right orientation, AC power adapter not properly connected, or after having batteries out and camera left unplugged for a long time and then plugging it in, you have not waited for a few minutes before turning it on. If the LCD screen will not come on, there is the possibility it is bad. If attention to these matters is unsuccessful, there well may be a hardware problem requiring a repair shop.
SOURCE: fugi digital camera 350
Your camera is broken. This should not happen. If it's in warranty, send it to Fuji for a replacement.
SOURCE: polaroid i631 digital camera
I have the same camera and the same problem, if you use lithium batteries it keeps the charge longer because regular batteries aren't strong enough. Hope that helps you! :)
SOURCE: New 2 GB Memory cards say cards full when installed
The SD card may have to be reformated. You should do this in the camera you want to use the SD card with. Do not format the card with your computer.
In you manual or on the menu of your camera there is a "Format" procedure. follow that and your camera will work again (REMEMBER) if you have images on the SD card down load them before you format the card.
Once you down load the images from your camera you should reformat the card to clear it in order to shoot more images.
SOURCE: memory card issue
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Then, insert the new card and do the format thing again.
