Question about Electronics - Others
I HAVE FLASH drive product 26466 when I insert into a printer, it showing me it is a read device only what does that mean
    Brigadier General:
  • 453 Answers
It means you can't write new files or alter the files.
It is cs26466 ?
this has a password protection feature apparently
is it an sd card ? move the tab on the side of it
If it is a usb flash drive I do not know how you get pass the passwor dor how you enter a password when accessing it ?
Posted on Sep 20, 2019
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 24 Answers
SOURCE: dvd combo not reading/writing any CD
since the device can't identify a disc anymore it is adviseable to get another.
Uzowuanya
e-mail: uzowuanya@yahoo.ca
Posted on Feb 13, 2008
Anonymous
  • 70 Answers
SOURCE: unknown device
you must install windows driver package to run it
Posted on Apr 15, 2009
dvdcdlaser
Dvdcdlaser
  • 1285 Answers
SOURCE: Can't find where USB Flash drive inserts.
USB port located at the front lower left
Posted on Aug 15, 2010
Jonathan Thomas
  • 4 Answers
SOURCE: wont read a flash drive
Make sure the flash drive will work on a normal computer. If it does try a different port on the xbox. If it works on the computer and not the xbox you might have to format the flash drive to work with the xbox Go here USB flash drive support for Xbox 360 or How to Configure any USB Flash Drive as Storage on Xbox 360
Posted on Apr 04, 2014
Cannot print from flash drive
One method, press the SCAN button (LCD will show Save to PC) then insert USB flash drive into the Direct Print Port. Use the left and right arrow button to select USB flash drive, then press OK button.
Second method, is press the FAX button then press the Menu button. Insert the USB flash drive into the Direct Print Port.
If you can access the USB drive using either method then you know the printer recognized the drive successfully.
Nov 05, 2013 | Canon pixma mx310 color ink-jet - fax /...
HPv165w recognized in Device manager...But cant open it in My computer..
Try inserting the pen drive into another computer to see if you can open the data on this pen drive.
If not you may need to format the pen drive.
Nov 24, 2012 | Electronics - Others
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My trancend 8 gb has become write protected. I used the regidit formula but the problem continued
Flash drive is write-protected, meaning there is damage to the firmware. To repair damaged Transcend firmware, use JetFlash Online Recovery software.
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download)
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
Before repaired
After repair
Oct 06, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
When I insert my LaCie iamaKey Flash Drive - 16 GB into my Mac computer it reads "The disc you inserted was not readable by this computer". I have tried it on other Macs and it says the same. It...
Some flash drives need to be formatted for the the device that you use it on.
the Mac you are using it on may not recognize the device and see it as incompatible.
Jun 13, 2011 | LaCie iamaKey 130871 Flash Drive - 16 GB...
HP Pavilion zv6000: USB ports are inop. USB port on rear of computer works fine. USB port on left/front will power my flash drive, but the light stays on constantly. The flash drive is does NOT show up in...
After reading the description, I think you need to try updating BIOS and latest device drivers for USB. Because USB are getting power on that means there would not be any fault to from the motherboard.
So please try updating latest BIOS for your notebook.
If you can provide me the product no for your notebook and the operating system which you are using currently then I can find the one for you.
Otherwise you can also do the same.
Type in the product no. on www.hp.com. Then go to software and driver download page, select the proper OS and search in BIOS ROM pack available for your notebook.
I hope this will help.
Jun 11, 2010 | HP Pavillion ZV6000 Notebook
My trancend 8gb pendrive when inserted dont show name of transend
Dont worry much about that, it's the way your PC recognises the device. you can rename the drive if you want in my computer
May 06, 2010 | Transcend (589307) Media
Imation USB not reading in My Computer
Insert the device and restart the computer. Does it shows a "removable disk" icon in My computer? If it does, go to the properties and click unblock, may it's block. If that doesn't work, then just reformat.
Sep 05, 2009 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
Electronics - Others Logo
64 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
