Question about Food Processors
Sumbeam vista fod processor model 84071 cant find manual and don't remeber how to attach blades.
  • 10,483 Answers
Searching using https://www.google.com did not locate a manual, but a Sears web site showed a drawing that might be of assistance to someone repairing it.
https://www.searspartsdirect.com/model/4rvivrs5qn-001037/sunbeam-84071-processor-food-processor-parts
Posted on Sep 18, 2019
2 Suggested Answers
6ya staff
SOURCE:
angeloioc
SOURCE: attachment stuck on shaft of food processor
put the mixing bowl up as much as possible. spray some wd40 into the groove between the attachement and the motor shaft. Wait for several minutes, then with a hammer and a piece of wood, give the bowl a good wack. With a few goes, it will gradually come off. I will be putting some butter inside the attachement from now on to keep it lubricated
Posted on Mar 09, 2011
I don't have an instruction manual (wasn't in the box) and I don't know how to use the slicing/shredding blades or the additional smaller bowls.
A manual for the FP-14C series which the Cuisinart site indicates is applicable to your specific model is available online:
http://www.cuisinart.ca/pdf/ibs/en/FP-14DCC_en.pdf
See page 8 for assembly instructions. Beginning on page 20 is an included recipe section.
For future reference available Parts & Accessories are listed here:
http://www.cuisinart.ca/cuisinart_parts_accessories.php?product_id=328&item_id=281&cat_id=7
Aug 13, 2011 | Cuisinart FP14DC 14 Cups Food Processor
I need a Euro-pro Quad Blade dood processor,capacity 6 cups, model EP91W: PROCESSOR COVER.
You DON'T want one. I had 2 and they both broke on the first use! Now I can't find the company to get my money back! Horrible product!!!!!!
Jun 05, 2011 | Euro-Pro EP91 Quad-Blade Food Processor
I have a Hamilton Beach Scovill 702-4 food processor that I have not used any other blades in for a long time. I wanted to shred cabbage for a salad and I could not figure out how to make the attachment...
I have been using mine for 22 years now! I love it and am actually looking for a replacement blade that I have somehow lost. Anyway, I think the end that looks like a half circle goes down into the base. The other end, starts out thin, then round, then square closest to the center of the 3" long "stick". This goes into the blade holder. Both of them have to be rotated to the correct position to fit right. Hope this helps! If you end up wanting to get rid of your blade, let me know!
Dec 17, 2010 | Hamilton Beach 70100 Food Processor
Have a sunbeam oster kitchen centre....mixer,blender, sausage maker...but no manual..1985 -86 model...help. #97108C ON MAIN BODY.It has stainless bowls, glass blender jug. Sure would love a manual.Thanks.
I have an Oster Kitchen Center by sunbeam. It has the mixer, blender and food processor. When I attach the processor to try to use it the blades do not spin. If I push the siler know down with an objest it will turn. Am I missing some little piece to make it work.
Sep 13, 2010 | Oster Food Processors
Bravetti Food Processor Model KP80B
That's alot of bad outlets.Are you sure there's nothing wrong withe the processor? Just kidding. How long have you had this processor? Any chance of taking it back?
If not, try this. With the unit unpluggedput an attachment on that you can hold onto and try to rotate the motor. Not all are tested and sometimes the motor brushes are not making good contact. If you turn it manually you may get lucky and set them to work. If you get it running, chk with power after several turns, run it constantly for abot 5 minutes to seat the the brushes. Remember to have it unplugged when you have your hand on the attach ment. Good luck. Ned
Aug 24, 2009 | Bravetti Quad Blade Food Processor
Stripped Blade Attachement
call this number
1-866-925-PART
as for this part number
D905801020007878 DISC STEM
its like 5.00 dollars
Aug 13, 2009 | Black & Decker FP1445 Food Processor
How to attach grating/shredding blades to GE Food Centre FP22
When you remove the regular chopper blade, it should fit on top of the stem. The chopper blade must be removed to use the slicer / shredder attachments.
Jan 05, 2009 | GE Food Processor
How do you remove the blender blades from the ultimate chopper?
Press and hold down the center shaft of the blade assembly and lift the blades straight up. You can go here: http://www.ultimatechopper.com/chopper_ul_manual_eng.pdf for a downloadable pdf copy of the user's manual.
Jan 03, 2009 | Ultimate Chopper Food Processor
How to attach Cuisinart blades DLC 8 to DLC7 stem
The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
-Tha Mp3 Doctor
Jan 01, 2009 | Food Processors
User Manual
Here is the direct link to your food processor user guide: http://useandcares.hamiltonbeach.com/files/840150200.pdf Enjoy Lolita
May 18, 2007 | Hamilton Beach Big Mouth 70590 Food...
Food Processors Logo
50 people viewed this question
Top Food Processors Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
