SOURCE: Wifi connection
maybe you had it in to long just let cool down for a few day because you had it in for a few weeks
hope this helps
SOURCE: mio 168 connecting to wifi usb adapter on pc problems
Buy SD WiFi card (eg Spectec SDW-821).
Prob only work with WEP/WPA encryption - not WPA2
SOURCE: wifi connection
Hello. The wifi switch should be on as indicated by the light beside it. Please press on Start-Connect to - then select a wireless network then click Connect. If you are asked for the password, please enter it. Click on Open Network and Sharing Center to check if there is a red x mark between the network and the internet or between the network and the computer icons. If there is none, please launch your internet explorer. Hope this works. Thanks.
SOURCE: not able to connect wifi in my lapopo
In connecting through a wifi, there are two factors to consider. (1) Wireless Router broadcast and (2) Wireless Receiver.
Make sure that your network router is broadcasting wireless internet or wifi. Also, you have to know if you need a pass key or password in order to connect to the wireless network.
Now, given that there is a wifi spot, your laptop should automatically recognize the wifi broadcast and negotiate connection without your intervention. This will only happen IF AND ONLY IF your laptop has a wifi radio receiver and that it is TURNED ON. When it is turned ON, it will connect you immediately if the network has no pass key set. If there is, then you have to enter that key when you try to manually connect it. (Right click on wireless network icon on system tray. Then it should say: Wireless Network Available. Then Click CONNECT)
To turn your wifi radio receiver ON, slide a switch button to ON position depending on your laptop model. If you dont have that kind of switch, look for the wifi icon printed in the keyboard keys. In some laptop, it is in F2. Now Press FN+F2 to turn wifi radio receiever ON and OFF.
SOURCE: no wifi connection
Usually, you just have to do a soft reset (Turn your phone off and back on) to make your wifi active again.
In the widgets look for your wifi then press search and it will locate
any wifi hot spot near you then choose then connect. then go to your
communication and choose which site you want to go.
