SOURCE: 18hp craftsman riding mower model#917.255913. won't turn left!
I have had this problem for the longest time. I replaced the secondary gear twice. Helped for a brief period and now won't turn left again. Replaced the steering shaft and worked for a brief period. Back to no left turns once again. The issue is with the secondary gear and bearings (plastic) which is only a temporary fix. What I had done was welded a piece of steel to the bottom of the steering shaft eliminating the secondary gear connecting directly to the tie rod for the steering. Works perfect now.
SOURCE: Can you tell me what
I can tell you this. I have a 17 HP Craftsman and the battery specs are:
28 amp hour
230 Cold Cranking Amps, minimum
My case size is U1R, but yours may differ.
A good auto supply store can probably look up your specs.
If your current battery is less than this, you may be correct about someone installing an undersized battery.
How does your engine crank if you use a car to jump it?
Let me know.
Gary
SOURCE: what is the valve adjustment?
its the clearance between the rocker arm and the valve on briggs engines i set them to .006
