Do what I did to my friend when she said hers was blocked. I got the fridge out so the outside end of the drain tube was visible and I could get my mouth on the end, Wrapped kitchen roll round it so as not to mess my lips and said to my friend that she should look closely at the hole in the inside of the fridge AND GET AS CLOSE AS POSSIBLE to it so she could tell me exactly what was going on.
So with her head up to the hole I blew as hard as I could. You can guess what happened... She swore a bit, but she has a good sense of humour and laughed, but she couldn't complain as her fridge drain was clear.
It's a tube - you don't need to undo anything...
SOURCE: clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
SOURCE: Fixing a clogged pump on GE Profile washer
waht u need to do is get a bucket now take the outlet hose and place it into it low to the ground if water comes out then it will be that your pump is faulty and needs replacing but if it doesnt the only way to do it is towels on the floor and with a low pan place this under the sump hose which should be in the middle of your drum which then leads to the pump pull slowly but not enough for the water to push the hose of do this until empty the only other way is to take it outside and pull the outlet hose of this is the quicker and dryiest out of them all but do do the first part to c if the pump is faulty m8
SOURCE: LG REFRIGERATOR - FREEZER ON BOTTON
You have not only to unplagge the unit, but also to pull out all of frozen, or cold food and other things like baskets etc. and to keep open all dors. All of unit, including inside parts, has to "warm" to home temperature and after that to stay as minimum 24 hours. If you leave frozen food iside unit and closed doors you have to wait a week or more. DON'T USE STEAMER! YOU WILL DAMAGE PLASTICS. DON'T APPROACH FROM BACK SIDE!
SOURCE: clogged defrost drain tube
You can access the drain tube from the back of the refrigerator. There is normally a trap located after the drain line exits the freezer compartment. Clean out the trap and it may solve your problem.
SOURCE: GE WJSE3110A washer, won't drain
On a scale of 1 -10, I'd rate this about a 3.5 in difficulty.
Un plug machine.
Use a putty knife to push the clips in at the seam of the front panel and the washer's top, about two inches in from each side to allow you to pull the front panel forward and then lift it off the bottom pegs.
If you took off that drain hose, you shouldn't have any water left in the machine, so take the two squeeze hose clamps off the pump hoses, the electrical wires off the pump, and the two 3/8 size bolts holding the pump to the washer's base.
Now check to see if the pump is plugged or obstructed with an object. Replace pump with cleaned out or new pump as necessary.
