Heavy Machinery Logo
Posted on Sep 17, 2019
My 2014 4021 skid steer has only 525 hrs on it.I ran it tonight for half an hour and it stalled . I let it sit for half an hour and it started right up, ran for 10 minutes and it stalled
samball2000
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Oct 13, 2019
samball2000
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
Helped
8652
Points
18
Try fuel filters and also make sure its not overheating. Coolant level, radiator plugged??
5 Related Answers
Anonymous
  • Posted on Oct 13, 2008
SOURCE: Car starts then stalls once the engine warms up.
You need new timing belt and gears. Buicks gears are made of plastic, and become a big glob. Nothing for the timing belt to grab onto.
A
Anonymous
  • Posted on Oct 24, 2008
SOURCE: engine intermitantly stalls
if this a fuel injected car just check to fuel pressure first.
Anonymous
  • 176 Answers
  • Posted on Jun 17, 2009
SOURCE: 1997 saturn sc1 stalls while driving or while
i would have the fuel pump pressure checked, connect a fuel pressure gauge drive around and monitor the fuel pressure
operating pressure 276-370 kPa (40-55 psi) Pressure decay in 5 Minutes 55 kPa (8 psi max)
Anonymous
  • Posted on Jun 24, 2009
SOURCE: Yesterday my wife and I ran some errands. Made a
My girlfriend had the same problem with my truck and it ended up needing the Cap and Rotor Changed
Hope that helps keep me updated
Anonymous
  • 3640 Answers
  • Posted on Oct 07, 2009
SOURCE: suburban stalls while driving
a bad crank sensor can cause this. shuts off while going down road, and will start about 10 min, later with no problems runs fine until it quits again. hope this helps,
Hello I have new holland lx565 skid steer,starts up shuts down after running fine about 1 minutes.starts right up shuts down.always been trouble free,approximately 800 hrs,changed fuel filter
Not to worry friend, when my car go sick i avoided going to mechanic looking for DIY_Repair when I fo und this website https://big-manuals.com/ and this book helped me repair it within an hour, all by myself!!!
From wiring diagrams, schematic illustrations, spark plugs info, parts info, chassis number, valve time settings, step wise instructions, torque specs, error/fault codes, engine info, to every single minute parts, you get everything in there you can't imagine how detailed it is
I have a John Deere 170 ( Kawasaki Engine), after mowing about an hour and get in some taller grass, it starts to sputter and then stalls. It will start up but still sputtering and stalls again (...
it sounds like the coil is breaking down at high temperatures. when a coil gets hot it expands. when it cools off it work right. i would change the coil and try it. i think that will solve your problem.
7helpful
2answers
Case 410 Uni Skid Steer Loader Service Repair Manual
Hi, I have a 2005 Case 410 that has 391 hours on it just had the oil and air filters changed 10 hours ago. While using the skid steer it suddenly shut down on me and wont start when I turn the key the hour meter reads ACC. I checked the voltage on the battery checked out at 13 volts coming out, and tried jump, no go. Checked the oil which was at a right level and seemed fine. Cane anybody help me thanks, email me at [email protected] Thanks
After driving for 15 min stalls. when i go to start it cranks but doesnt start. after one min of sitting starts right up.repeats every half hour
Sounds like you need to replace the ignition coil,they heat up and go open but when allowed to cool they make contact and then the engine will start.
3helpful
94 chevy cav. after driving for a while, the car shuts off when u break. it will start back up but stalls as soon as you put it in a gear. let it sit for half hour and it will drive again for a while then...
94 chevy cav. after driving for a while, the car shuts off when u break. it will start back up but stalls as soon as you put it in a gear. let it sit for half hour and it will drive again for a while then starts the process all over again. any suggestions
My 1996 nissan sounds "clogged up" Once and awhile white smoke comes out of the muffler, but not consistent. When I first start it in the morning, it stalls about 3 to 4 times and then seems fine. ...
Sounds like water in the fuel system. White is water in the cylinders. Check the fuel filter and let me know. If its not this then I will advise further. Cheers
2answers
Test for weak spark when it wont run....my guess is that its the ignition module inside distributer...they heat up and shut off spark,then cool down and work again for a while...good luck..Lee
Top Heavy Machinery Experts
ADMIN Andrew
ADMIN Andrew
Dmitry Isayev
Dmitry Isayev
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
