SOURCE: Hilti TE-60 hammer drill
what I would do if you have a fax machine is call 1-800-879-8000 and request a schematic on this tool first. Some of their products are not that easy to disassemble. I never have worked on the TE-60 but have on some of their other products and they are all different. Hope this helps
SOURCE: HAVING A PROBLEM WITH MY HILTI TE5 HAMMER
the bearing in the chuck is probly missing. replace the ball baering.
SOURCE: Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
SOURCE: drills but dont hammer te 74
Hilti no longer carries parts for the 74. However most of the TE75 parts will interchange with the 74
SOURCE: Hilty TE 12 Hammer Drill Wont Hammer, but will
Parts are no longer available for the TE12. Be carefull if you try to take it apart yourself. Some of the older models had a lead based grease in them
The end of the drill is 2 parts hold the bottom part(closes to the drill) and turn the top part (the end the bits in) and turn it a 1/4 turn counter clockwise that opens the chuck then pull the bit out to replace do the opposite. Don't let the end at the drill spin or it will come off the drill completely if that happens simply line it back up and tap it hard to get it back on
