Question about KitchenAid Refrigerators
Kitchenaid superba keeps beeping.Shows F1 & door open. How can I fix this
6ya staff
SOURCE:
catriver
Ron Marek
  • 878 Answers
SOURCE: Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Posted on Mar 08, 2007
MicrowaveSvc
William Miller
  • 9177 Answers
SOURCE: KitchenAid Superba Microwave/Oven, Microway Door message
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 27, 2008
Anonymous
  • 242 Answers
SOURCE: in door water dispenser leaking on my kitchenaid superba
Hello , I can help , If water is coming out of the tube in the door the only problem you could have is the water inlet valve not sealing all the way causing water to seep out and leak, this is normal to happen over time and the only way to fix it without turning your water off to the unit is to replace the water inlet valve , it is not extremly difficult and will cost about 50 dollars. it is the part that you connect your water line to in the lower rear of the unit. This should get you going if you have any questions just ask. tell me how it works out.
Phil
Posted on Jan 07, 2009
Fred Yearian
  • 5603 Answers
SOURCE: my kitchenaid superba oven is permanently locked
There is a motorized latch. TRY turning off the circuit breaker for a minute and then back on and see if the control will reset the latch.
Make sure any controls are set to off.
Posted on Sep 26, 2009
dwastchak
  • 4 Answers
SOURCE: Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Posted on Jan 24, 2010
My beep quit! Beep used to work when the oven came up to temp, the timer timed out, or a button was touched. Can it be reset or will I need to replace it? Where's the control board located and how do I...
We have a Kitchenaid Superba gas stove and the beeps would not sound. We thought the control panel was shot, but we have a WONDERFUL repair man. Here was his re-set.....open oven door, push the cancel button, push stop-time button and hold that button for about 5 seconds. When the beep sounds let go and the panel is re-set. WOW!!!!
Oct 23, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Kitchenaid superba side by side refrigerator over temperature...
I think I may have the solution, after having suffered through the same problem for months. I have a Kenmore Elite side-by-side which is really the same as KitchenAid and Whirlpool. Having thought of complicated solutions first, I have finally gotten back to step 1, simple solution. Tape the switch on the top of the freezer compartment and see if that works for you. I believe the door while seemingly closed is not pushing the switch in far enough. If that works for you, you can probably glue something to the top of freezer door so it can push in the door switch a little better. The reason that it beeps is that the switch is not pushed in enough and the light is still on inside while the door is closed. The refrigerator then thinks the door is still open. I really hope this works for you as I can sympathize with you having listened to the beeps for months. I feel sorry for people who have changed one circuit board after another to no avail. And there are so many stupid repairmen out there offering dumb advices and perform needless repairs.
Jul 14, 2009 | KitchenAid Superba KFRS361TSS Stainless...
Problem with KitchenAid Superba KSRG25FK Side/Side Refrigerator
I found you looking for keep en mind kitchen aid is made by whirlpool good luck :) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504094
Jun 12, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Beeping or Chirping
probalby not relates, but the beeping is ususally accompanied by an indicator light as to why its blinking, perhaps the door open alarm???
Mar 28, 2009 | KitchenAid KSCS25FKSS Side by Side...
The door is locked
Put the unit back into a clean cycle, wait 2 minutes and then push cancel, the door should unlock
Jan 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
Over tempature reset keeps beeping
its registering a warm temp, you reset it but when it checks again in 2 hours or so its still seeing a warm temp whichi s why the alrm is going off, id look at the contents of the refrig for signs of defrosting, icecream not hard enough, ice maker not producing and melting, moilk spoiling premature, butter too soft.
Nov 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Oven door hinge replacement installation
kitchenaid superba oven door will not stay closed.
Oct 22, 2008 | Kitchen Ranges
Refrigerators Logo
62 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
