Robert N Mary Sears Posted on Sep 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Denon avr 5805 starts up and emeadatly shuts doun
Bob Kirkwood
Level 2:
Novelist:
  • Expert 175 Answers
  • Posted on Feb 08, 2024
Bob Kirkwood
Expert
Level 2:
Novelist:
Answers
175
Questions
Helped
35946
Points
378
More than likely the mosfets are shorted in the output stage.
5 Related Answers
Robert Johnson
  • 395 Answers
  • Posted on Jan 13, 2008
SOURCE: Denon AVR-681 receiver
this manual is the same as the 681 the only difference is the front input and power difference. this web sight http://www.usa.denon.com/AVR1602_682_ownersmanual.pdf
EBC ELECTRONICS
  • 163 Answers
  • Posted on Jan 22, 2009
SOURCE: Display on Denon AVR-2307 won't work
1. Bad main transformer or
2. bad main fuse/ bad channel.
You need a repair shop.
Anonymous
  • 119 Answers
  • Posted on Mar 02, 2009
SOURCE: Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Anonymous
  • 92 Answers
  • Posted on May 18, 2009
SOURCE: AVR-589 Denon Receiver Keeps Shutting Off
even if the wires are not touching they can still arch. make sure there is no bare wire showing ie. cannot see any unshielde speaker wires. id unplug then replug back in
budgie140
Ian Summerfield
  • 502 Answers
  • Posted on Jul 04, 2010
SOURCE: problem denon avr 1910
most electrical units have a fuse inside,try taking cover off and checking for blown fuse,or,take it to radio repair shop.My Harmon Kardon stopped after 3 years,and the report said the unit that failed was quite a common problem for the modern multi channel amps,quite cheap to fix..All my tips are free
1helpful
LOST LEFT FRONT SPEAKER AND CENTER SPEAKER
Check all connections and the balance settings. (Left / right/centre) If these are ok, the output system on the amp has probably failed. Denon are a good unit. See if there is an Agent or Amp specialist nearby that you can take it to.
2answers
How can i connect my denon 5805ci with my new tv 4k & 3D sony 65"
Are you sure that model is HDMI v1.4 compliant? I know my Denon 8508 is not so I use optical outs to get 5.1 surround sound.
Denon AVR-1513
disconnect speakers then try again if still shutting down you will have bad outputs.
The speakers on TV mode work but when I go to play DVD no sound.
How have you connected sound from the DVD player to your AVR-5805? If optical (a good choice because it sends surround sound with one cable) then you will need to choose optical audio in your DVD signal path. Similarly, you need to choose analogue if used or even composite (not a good choice)
AVR 5808 purchased in 2005 with Serial #4101500049. HDMI input jacks are not working for video or audio. Also, if it can't be fixed then I may want to add an AV processor, but need to see if that...
Hi Steven,
First of all, thank you for purchasing the Service Manual of Denon AVR-5805.
Please email me at [email protected], I will send you the PDF file format of the service manual. It is a 16MB and can't be uploaded here.
Thank you for your patience!
Rating and feedback are highly appreciated!
mjsazon
Were does the center speaker connect
second row down.. not sure if it left or right side.. but one is a blank.. so don't use it for anything.. My guess is if your looking from the front of the unit it is the one on the left.. my 5805 just lost sound.. sucks...
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
