SOURCE: "Lock on" light keeps flashing - cannot run dishwasher
same issue..
Other boards suggested heating element issue - but nothing very clear or compelte.
SOURCE: Green "Clean" light keeps flashing, dishwasher won't start
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
SOURCE: The clean light in my Kenmore dishwasher keeps
It has to do with the water temperture, either the water entering the dishwasher is too cold and the heater can't get it up to temp, or the heater unit has problems... Push the Air dry ,then the sani wash buttons a few times and all the lights will light, it resets the computer .
SOURCE: Hi All my powerpoint dishwasher 1dw12 keeps
Any
water that leaks (for whatever reason) from the internals of the
machine finds it's way down to the lowest point of the machine - down
under the washzone and into the area where all the workings of the
machine are located. There's a sensor there (a polystyrene float
operated switch in fact) that detects this water - causing the machine
to empty and go into error 4 (E4).
The solution will depend on
the nature of the leak. If it's due to one of the various seals on the
floor of the washer leaking or there is some problem with water level
controls then that will have to be repaired first - otherwise you'll
keep on getting the error. In my case however, the "leak" was actually a
design feature of the machine and is easily rectified.
Open the
dishwasher door fully and look at the floor of the machine where it
meets the bottom of the door. You'll see a couple of plastic tubes
protruding from the floor by about 12mm - one to the left and one to the
right. Their function appears to be to act as an overflow if the water
level in the machine gets too high (for whatever reason). This excess
water is directed down these tubes and into the bottom of the machine
where it can be detected - rather than letting it spill out onto your
expensive floor. The weakness in this system is that it only takes a
soup spoon of water to produce the error - something which might
accidently happen during the course of a normal wash.
Options:
1)
Leave the machine idle for a few days until the water evaporates. The
sensor switch will reset and the error will be gone when you switch on.
For
either of the following solutions, turn off the power to the machine by
unplugging it or tripping the relevant switch at your fuse board
The
stainless steel washcabinet is only slightly thicker than aluminium
kitchen foil. Handle the machine gently and never force it otherwise
you're in danger of distorting the cabinet.
2) Tilt the
machine right the way forward so that the water leaves the area of the
sensor. It'll flow back again once you level the machine but in wetting
the floor area of the machine, the level at the sensor will be a little
lower than before - permitting the sensor to reset. Switch on and the
problem should be gone.
3) Pull the machine out from the built in
unit to gain access to the right hand panel. Remove it (just a lot of
philips screws holding it on) and you can just about see the polystyrene
float (near the front) and the slightly depressed area underneath it -
in which the water accumulates. You can poke a stick in with some tissue
taped to it to mop up the water. Be careful not to disturb or damage
the float.
note:
I've had this problem occur twice in
as many years. If it keeps on occurring then you likely have a genuine
problem with water level controls during filling or a leaking internal
seal dripping water into the bottom of the machine.
Don't be tempted to block the overflow tubes - a genuine overflow could destroy your kitchen!
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
