SOURCE: what is the problem with
Did you replaced both back light inverter boards in your Dynex 37 inch tv?
What is model number of this tv?
Does power supply board provide correct voltages to back light inverter boards?
Let me know above info to diagnose problem.
Thanks.
SOURCE: Samsung 32'' LCD TV backlight works occasionally
Check for any loose soder points or loose connections with wiring sockets to backlight inverter board.
SOURCE: hdtv screen turns on but is black
Chances are its the Inverter. However since the audio doesnt work either its also possible that the main board could be the cause. As in most cases audio will still work when an inverter fails. so its about a 50% for each board when the audio doesnt work either. You can get some free assistance yo help troubleshoot which board is at fault from www.tvcircuitboards.com they should also have replacement boards for your model.
SOURCE: how to replace the backlight inverter board on Samsung smart tv UN55ES6100F?
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
