Question about Yamaha Audio Players & Recorders
Yamaha rx-v371, Front 2 speakers wired in and work fine. Surround R + L + Center are wired in but won't work. What should I do to fix(reset?)
    Loyalty:
    Visited the website for 30 consecutive days.
  • 130 Answers
Surround R + L + Center are wired in but won't work Voltage for all relay drive seems OK.
What you should do is to exchange the front speaker relay with
those suspected such as SR and center. If sound comes out,
the problem must be relay. If still gets no sound, check all circled components. Remember to download service manual and read p.83.
Yamaha rx-v371, Front 2 speakers wired in and work - yamaha. jpg-ptbjva130n4dgelctepctips-2-0.jpg
Posted on Sep 13, 2019
Anonymous
SOURCE:
Anonymous
  • 245 Answers
SOURCE: No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
Posted on May 23, 2009
Anonymous
  • 30 Answers
SOURCE: Sony HT 6500 receiver...center speaker jack
try to spray contact cleaner into the speaker port itself.. Powered off of course.. let it dry and try again.. this will clean any connectivity issues due to bad contacts.. as far as replacing jacks.. try the suspected "bad" speaker and wiring in another port.. if it works then the speaker and wiring is good and you have to check actual jack in which you were asking and back to auto amplifier circuit or transistors.
Posted on Dec 17, 2009
Marek Podmaka
  • 127 Answers
SOURCE: Yamaha RX-V365 Receiver when I hook up my center
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
Posted on Oct 07, 2010
istadmin
SOURCE: Yamaha RX-V365 Receiver, Yamaha NS-AP2600S(BL) Speakers
I have the same issue. I took the speaker apart and tested with a meter and both the mid and tweater were wide open, in short blow out. Not sure what caused this but the speaker needs to be replaced.
Posted on Jan 14, 2011
ericvaudio
SOURCE: yamaha rx-v1600. I am failing in my attempt to get
After 6.5 hours, I am now listening to music outside on my patio using my rxv-1600!
Connect your speakers to the Presence Zone 2(3) output on back. Then power up amp and select zone 2 on front of amp. Nothing will happen, because as I found out, you must route an input to zone 2 or 3. Which is cool, because you can listen to something outside that is different from your inside.
You select what to route to the zone by pressing Zone Control button, just right of zone 2 and 3 button. While you see red zone light blinking, rotate input select knob to prefered input, i.e. radio/cd/aux/etc... also, you can adjust volume by pressing zone control and turning up the volume knob, only while ZONE light is blinking.
hope that helps, i know i was frustrated figuring that out!
Posted on Aug 01, 2011
Yamaha Receiver RX-V371 broken speaker wiring connection on the back, what are different solutions?
That unit give you the option for a second set of speakers ?
If so , connect to Output 2 ( or B) on the speakers connections and select Spkr 2 ( or B) from the front panel
Dec 16, 2014 | Yamaha Audio Players & Recorders
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
No surround sound
firstly Jessica you will need either a cd or some form of media that is recorded in surround sound then make sure all wiring is in it's right sockets then while your "cd" is playing configure the amplifier. I hope this will be of some help goodluck.
Nov 26, 2013 | Yamaha RX-V373 5.1 AV Home Theater...
Yamaha rx-v371 shuts off 2 secs after turning on
Return unit to place of purchase, this is clearly a manufacture defect. The warranty will cover full replacement, do not allow them to attempt repair on the current item because you will be back and forth until warranty runs out.
Apr 02, 2012 | Audio Players & Recorders
I have a yamaha RX-V461B AV receiver. I cannot get the the right front speaker channel to work. All the surround and center speakers work. Even when I run the speaker test, no static comes out from that...
There is no setting that would choose one front speaker to work differently than the other. The amp or something in the audio path within the receiver is failing.
Aug 25, 2011 | Yamaha HTR-6030 Receiver
Make sure the speaker select switch is on "A or B or AB. It's a small button on the front panel of the receiver (pen sized) and will give you visual feedback on the LCD display. If they are on, you need to have the unit bench tested at an audio shop and possibly repaired. Hope this helps
Jun 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha RX Z9 and two-channel system integration
The A-B speaker switch is intended to direct amplifier output to a pair of speakers in a different location when set to B.
Feb 26, 2017 | Televison & Video
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
