Nokia 3110 Cellular Phone Logo
Posted on Mar 11, 2017
Transfer of Saved Messages to PC
Intro:
I use a Nokia 6125. And I also use Nokia PC Suite 6 and connect my phone to the PC via Bluetooth.
Situation:
The phone performs well. Transfer of data / files from phone to PC and vice-versa are at their best. I have backed-up my contacts. I have also backed up messages from Inbox and Sent items. I had moved some messages from my inbox to the Saved Messages folder. The Saved Messages folder does not appear on the PC Suite. I'm not able to move the messages back to the inbox either- there is no option to do that. I created a new folder in the Saved Messages folder and noticed that it is visible in the phone browser on the PC. but when I moved messages into it and checked the browser on the PC, the new folder is still visible but the messages aren't. I need help in transferring those messages that are in the Saved Messages folder from the phone to the PC.
I have 249 messages in the messaging inbox of nokia 5230 of which 243 are bluetooth messages. But when connected to pc through nokia pc suite 7.1.62.1, the bluetooth messages are not displayed on the pc....
Hello.Try to browse the file by using Oxycube.Install this software and connect you phone via USB with the selection of PC Suit when message prompt.After you have connected your phone just open the message folder..If the files are in hidden mode Pc suit cannot help.Good luck
4helpful
3answers
I want to print text messages sent to my cellular phone
Oh..........dear user please format your mobile after 5 u can solve this problem.thanx
1helpful
How to install E63 themes?
There are three ways that you can install your Nokia themes on your phone. One is through over the air downloads, in which case, you just go directly to the site with your chosen theme, click on the link, and follow the instructions on your phone.
If you're downloading the themes on your PC, there are two ways you can install it on your mobile phone. One is through the Nokia PC suite, and the other is through Bluetooth or data cable transfer. follow these instructions
Using Nokia PC Suite:
1. Connect your phone to your PC and turn on the Nokia PC Suite or wait for the application to start.
2. Click on the "Install Applications"
3. When a window appears, browse to where you have saved the downloaded themes using the left part of the window.
4. Select your chosen theme and then press the arrow in the middle of the window
5. Follow the instructions on your phone screen and you're done.
Bluetooth or Data transfer (only for N-series and newer phone versions)
1. Data transfer. Connect your phone via USB cable and select "data transfer" on the mode menu. When you connect your phone and it shows up as a removable disk, transfer the theme on your phone's storage card. You can install the theme by using the file manager and selecting the theme to install. 2. Bluetooth. If your friend has a theme on their phone, you can have them transfer it on your phone via Bluetooth transfer. The theme will appear on your messages and to install it, simply click on the transferred file on your messages and follow the prompts.
hope this helps...
There are some issues with the software on my phone and i have to get it installed again. However, in this process i'll lose all my saved messages and contacts from the phone memory and i don't want to...
As you dont want to lose your saved messages and contact you can transfer it to your computer using data cable and nokia PC suite.
Please download the PC suite and install it.
Connect your mobile to computer and you can transfer all your content from mobile to PC.You can transfer your calender entries also.
You can download the PC suite from below website
http://www.nokia-asia.com/support/download-software/nokia-pc-suites
Thank You
2helpful
2answers
I WANT TO CONNECT N 72 TO MY PC
N72 can be connected to your PC in two ways.
1. By USB cable
2.Via Bluetooth.
Bluetooth means you need to buy a device called Bluetooth dongle to provide bluetooth connectivity to your system.
For both usb and bluetooth, you need a software called Nokia PC Suite to access the mobile contents and for data transfer
1helpful
Can I copy the text messages to my pc from my Nokia 6131 ?
Is your phone provided with data cable... If your phone has bluetooth connectivity, you can transfer all the stuff from your phone to the system. For that you need to provide bluetooth connectivity to your system. This can be done by the addition of small pendrive like device called Bluetooth dongle. This will give bluetooth connectivity to your system. Then you need a software named Nokia PC Suite. Install it and you will find options there to transfer messages, music, videos and even more.!!!!
Want to TRANSFER PICS FROM NOKIA PHONE TO VAIOPCG7154M VIA BLUETOOTH. NOT HAPPENING.
install latest nokia pc suite version in your vaio you will get it from nokia site www.nokia.co.uk after downloading install it swtich on the bluetooth in your vaio and run the pc suite application keep your phones bluethooth on pc suite automatically traces the phone once it get connected it will as for passcode enter 123 from your pc and enter 123 from your mobile too . then go to my computer click on nokia browser from their chose your image folder transfer the file from phone to vaio via bluetooth and and you can also transfer from vaio to nokia phone also
7helpful
2answers
Phone Book Transfer Nokia N70 - Blackberry 9000
Syncronization! The Nokia phone will not just easily transfer or sync the contacts to your Black Berry because they are running on 2 different softwares.
In order for you to transfer all the contacts to your Black Berry is through synchronization
The Nokia N70 came with a CD called the Nokia PC Suite. And Black Berry should have a sync software.
What are the things you need:
1. Computer
2. Nokia N70
3. Black Berry phone
4. Nokia PC Suite CD
5. Black Berry sync software
How:
1. Install the Nokia PC suite to the computer.
2. Connect the Nokia N70 to the computer.
3. Export all the Contacts from Nokia N70 to your computer (refer to the manual)
4. Once the contacts are saved in your computer, disconnect the Nokia and connect your Black Berry.
5. Run the sync software of Black Berry and import the Contacts that are saved in the computer going to your Black Berry (refer to the manual of Black berry).
This is hiow to transfer the contacts from one phone to another.
I would also suggest to contact Nokia so that you will have a clearer idea on how to do it.
I can't receive and send a message by using pc suite
hello there!! thanks for using Fixya.com!
I guess these requirements will help you...
Requirements
To send and receive SMS messages via a mobile phone using a Windows PC, you need:
  • a mobile phone that can be connected to your PC (some mobile phones do not have an interface for connecting to a PC)
  • a Windows program that can control the mobile phone to send and receive SMS messages
Today, most mobile phones support at least one of the following options to connect to a PC:
  • Via infrared (IrDA)
  • Via Bluetooth
  • Via a USB cable
  • Via a serial cable
The infrared and Bluetooth option should be very useful to many notebook computer users since nowadays many notebook computers have built-in infrared or Bluetooth support.
The Windows program for sending and receiving SMS messages is provided by some mobile phone manufacturers. For example, Nokia offers a software package called Nokia PC Suite to their mobile phone users. It can be downloaded free of charge from Nokia's web site. Microsoft has also released a free program called SMS Sender that enables Windows users to send SMS messages via a GSM mobile phone from a PC.
In the following sections, we will explain how to use Microsoft SMS Sender to send SMS messages on your Windows PC.
Hope this will help you..have a nice day! Or try to reinstall the CD (pc suite) on your laptop or pc, this will make it very helpful as well.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
