Well a savage model 99 from late 1800s would be a collectible and should be cleaned with soft cloth bore swabs and a lightly oiled clothed rub down.
If its dirty or lightly tarnished NEVER use abrasive or polish on it. The tarnish is called patina and is its character. That gun values from $250-$3500 depending on condition. If rusted out I would take to a professional gunsmith for help. A Professional...
SOURCE: 99 cadillac deville
hello i have a 1998 cadillac deville course. an i been having the same over heating problems with mine i been taking it to mechanics an no one seems to know even the caddy dealship its overheating i checked the termostat water pump radiator all hoses was wondring could you tell me what you did or what you are doing to fix your problems my email is [email protected] thank you very much
SOURCE: 99 RX300 Engine code keeps coming up lean
I just had the same thing happen to my 99 RX300. I replaced the MAF sensor and cleaned the throttle body. We cleared the codes and check engine light came on again... with a knock sensor code. Had to replace knock sensors. Found some great info on how to do that here. http://us.lexusownersclub.com/forums/index.php?showtopic=41266&mode=threaded Car drives great now!
SOURCE: how old is a browning a5 shot gun ser. # 9G 40135
Go to www.firngline.com and post your question. There are lots of experts that monitor that site
SOURCE: nail not firing, battery charged, fuel cell good,
When you took it apart to clean it, you may have piched off the large brown o-ring on the head valve. To check this, take the orange head valve cover off and push the gun downard onto a piece of wood as if firing it. Watch the o-ring to see if it clears all the metal fingers around the fan.
SOURCE: gun does not fire every time
When you cleaned it, you may have pinched the large brown o-ring that is around the fan. Take gun apart again and reassemble. before you place the orange head valve cover on, press the nose of the gun into a wood surface and assure the o-ring goes into chamber unrestricted. Basically, the aluminum fingers of the cylinder should not pinch off the o-ring.
Testimonial: "I ordered a rebuild kit and this took care of the problem!(spark plug, new filter o ring etc) Thanks for all the assistance!!!"
