Amana ATB1832AR Top Freezer Refrigerator Logo
Posted on Sep 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Freezer not getting cold. compressor running , fans are runing. i cleaned coils
Marat Brikov
Level 3:
Director Badge:
Uploaded 100 video answers.
  • Amana Master 518 Answers
  • Posted on Jan 16, 2016
Marat Brikov
Amana Master
Level 3:
Director Badge:
Answers
518
Questions
0
Helped
324244
Points
3123
Thats really bad problem. You most likely will need professional look at Your fridge.
fixing restricted sealed system.
replacing compressor.
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Sep 14, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
2468
Points
21
If the compressor is running for sure you have 1 of 3 possble problems.
1. compressor is inefficient
2. You have a sealed system leak
3. You have a restriction in your sealed system all three of these require a service tech to detect or fix
Kenmore Elite series side by side refrigerator serial # 79571033010
Probably low on freon(which means a leak) or a blockage in sealed system. Both costly repairs.
3helpful
Refrigerator wont get cold
If compressor is running check and make sure your cond. fan and evap fan are running. Also check in freezer and make sure evap. coil is not covered in ice. Also clean your condenser coil. You could be low on refrigerant. There are quite a few things to check.
Mainboard location
There is usually a thermistor in the coil inside that switches the fan on after defrost. It might be open circuit or the coil may not be getting cold enough. Check the condenser is clear and clean and try a thermometer in the evaporator (coil inside) to see how cold it's getting.
Fridge and freezer warm. condenser fan, evaporator fan and compressor running, cleaned condenser coils, new defrost heater and defrost thermostat. Still no cold air?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
My GE refrig. Model dss25srdss runs but does not get cold at all I opened the back panel the compessor runs and so does the fan but the fan seams like its runing slow.
heatman101
Not cooling eithier side fan runing in back
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Refrigerator and freezer were working properly before an extended vacation. Cleaned both refrigerator and freezer, unplugged, and left doors open. Upon return plugged in and have waited 72 hours. ...
Let's think this through a bit....
You say it is cooling but it seems too quiet.... is the compressor runing but the condenser fan is not??? that would make it cool but not cold and also make it more quiet...
If both compressor and condenser fan are running... is the evaporator fan... the one inside the freezer running? That also could cause the same problems...
Is the compressor running all of the time??? or is it cycling? if it is cycling then it could be a t-stat or sensor problem....if it is not starting properly it may be a capacitor/relay problem...
These are alll things that you can easily check yourself....
If they all checkout... then the unit may have a small refrigerant leak and just will not cool enough now to catchup from a earm condition....
To check that out you would need a tech. to attach gauges to the system and check the charge...
heatman101
1helpful
Sub zero 611 refrigerator error code 40, freezer will not get cold enough but refrigerator compartment working
code 40 compressor for the freezer side over runing. check the coils upper part of the unit. or condenser fan motor. easy things to check.
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Refridgerator freezer not geting cold
Your compressor has shorted out. The compressor shouldnt be scorching hot just warm. And that humming you are hearing is the compressor trying to start but it is shorted. There is nothing you can do except for replace the compressor.(or the refrigerator)
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
