Watches Logo
D
Digby Rush Posted on Sep 10, 2019
I have an old ( 1987 ) Citizen Noblia wrist watch serial number 7903-953142SA and cannot find a replacement battery SR 910 SW for it anywhere in South Africa. Can you please
Stuart Lomas
Level 1:
  • Contributor 27 Answers
  • Posted on Oct 06, 2019
Stuart Lomas
Contributor
Level 1:
Answers
27
Questions
0
Helped
11836
Points
40
Find their website & they will have a listing for international service centres.
5 Related Answers
Anonymous
  • Posted on May 26, 2008
SOURCE: citizen 0510
The battery model number that needs to be replaced should be located on the outside of the back side of the wrist watch and if not you can always open the watch up and look and see what model number is on the gbattery itself. If the battery is not the problem then you may need to take your watch in and have a professional person to look at it. Hope this helps you.
Anonymous
  • Posted on Sep 08, 2008
SOURCE: I have an old Citizen
The battery is a SR920SW. A 1.5V silver oxide. Available from Jaycar Electronics, catalogue part number SB-2534. Around $1.80 each.
You may find that the problem is not the batterys but some other part to do with the mechanisim.
Regards
Col
(aka VK2CRT)
Sydney, Australia
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 12, 2009
SOURCE: citizen model number
Follow this link and download info and instructions for your watch:
http://www.citizenwatch.com/Technical/English/Full/E110_ebook.pdf
Rate me, please.
nalin_elliot
Nalin DSouza
  • 224 Answers
  • Posted on Jun 19, 2009
SOURCE: How do I set my Citizen WR 100 wrist watch.
http://www.citizenwatch.com/Technical/English/Full/C300_ebook.pdf
this is a dpf file that will show you how to set your watch
Anonymous
  • 1970 Answers
  • Posted on Jun 25, 2010
SOURCE: replacement band
mcdevito75 here, Look for a small watch repair shop in your area, to save on costs, new band and labor.
I have a citizen elegance water resistant watch with serial number 891188. I need 2 links added onto it for it to fit me.
My watch is an Elegance that is thirty years old with sentimental value. I don't know how old your watch is or how much you want to put into it. I would contact Citizen to see if they could fix you up with something if you haven't done so already. They should have these watches cataloged. You may have to send it back to them.
How to a recharge a citizen eco drive silhouette ladies watch..model number sy2030-54E?
Do you mean, you haven't been wearing that watch but to put it in the drawer for a long time?
If so, to recharge the battery, just put your watch outside or anywhere it can catch the sun ray or day light. After few hours or about a day, the battery has been re-charged and your watch will work.
If it still doesn't work after doing that, buy a new watch. Don't bother to repair the watch or to replace the Eco-Drive battery, because of the cost.
1helpful
I have a ladies Citizen Noblia 4420E without a battery and need to know the correct battery #. The diameter appears to be 5.8mm.
Im sorry. Unless it is printed on the back of the watch, or you have the battery, or it is printed in your manual, no one can tell you what size is needed. I will send you a link that you can use to determine what size you need. The best I can do.
http://www.watchbatteries-usa.com/size.html
Best regards.
2helpful
2answers
Noblia 12 meter watch setting time? I have no
Noblia are made by Citizen watches and you should go to their web site for instructions.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
Feb 23, 2010 • Watches
Repair to glass and new Link
The address of UK center for Citizen is below
CITIZEN WATCH (UK) LTD.
BERKSHIRE
P.O. BOX 161, Wokingham, Berkshire , RG41 2FS
TEL: (0118) 936-8855 / FAX:(0118) 989-0536
[email protected].
1helpful
Does the Citizen Calibre 2100 have a battery that i can change, its been in my top draw for over a year and has stopped working, i have left it in the daylight to charge but the eco drive needle is still...
Citizen EcoDrive does not have calibre 2100. This is ordinary quartz calibre and uses battery SR-626W. This battery will last for 2 - 3 years and is not rechargeable.
You can check for yourself using this link:
http://www.citizenwatch.com/CUK/English/home.asp
Rate me, please.
Battery Number for Citizen Diver's Watch
Energizer 371/370 It uses 3 of them. Careful when opening. Make sure you put the screws back tightly. unit has a gasket. lightly treat with vasline before putting back gasket and screwing cover on.
Citizen 0510
May 26, 2008 • Watches
Top Citizen Watches Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Citizen Watch Expert? Answer questions, earn points and help others
