Question about Kenmore Refridgerator Air Flow Diffuser Part W10151374
1200 norcold board wiring with icemaker
I needthe wiring diagram for 1200 norcold refridge
We have a Norcold model N811FLT, it is connected to power, but is continuously running on gas. We've tried resetting it with no change. Could it be the power board or the control board?
you can reset the control board . to do this you must ground the # 15 terminal with a jumper wire to ground. this is usually the terminal next to the white & violet wire. check diagram.
Jul 07, 2014 | Thetford Norcold RV Cooler/Freezer
Norcold 1200
replace temp sensor if same control board
Feb 15, 2014 | Dometic Refrigerators
Refridge not working
Even if your plugged in, you'll have to confirm you have 12Volts DC going to back of fridge at connections, behind vent cover. Is the upper board on front of fridge lighting up when you turn it on? Could you also give me model number off fridge to help guide you better ? Model # should be on inside of fridge.
Dec 08, 2011 | Rv Motorhome Dual Co & Lp Gas Alarm...
GE refridge icemaker won't work
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 03, 2010 | GE Refrigerators
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
Ice maker won't work
Check that lines are not frozen.
Check the inlet at the back of the fridge, ensure is not blocked.
Defrost unit completely to ensure it is not a frozen lines problem.
Check icemaker inlet valve, solenoid, and mechanics.
Here diagram and parts for your fridge's icemaker.
May 20, 2009 | KitchenAid Refrigerators
I have a norcold refrigerator in my rv. it works
Check if you are getting voltage to the heating element should be 120 volts
Apr 27, 2009 | Thetford Norcold DE0051 Refrigerator
Kenmore Refridgerator Air Flow Diffuser Part W10151374 Logo
97 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
