This may be a multi issue problem. Start with changing the wii position. If ur trying to run a disk horizontal, then chamge unit position to try it verticle. If that doesnt work u may have to do some machine surgery.
Testimonial: "The game store cleaned the disk and the main menu recognized the disk but when I actually tried to play the game, the error has occurred message came on"
It’s very likely your dvd reader has gone bad. Happened to me. It’s possible to replace the disk drive, but you should be comfortable with working with electronic components.
SOURCE: Wii "unable to read disc"
If Wii gives Unreadable disc, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
SOURCE: Brand New WII Console won't read any disc's
If Wii gives Disc Read Error, first step you need to check is to try
kind of Wii Problems Reference Fix Guide.
SOURCE: "Unable to read disc" Wii
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
134
SOURCE: unable to read disc message on Wii
Try a cleaning disc. this may fix this issue. if the issue remains, it will confirm a major problem within the optical assembly. you will need to replace the optical assembly in this case. it has failed.
Contact Nintendo for the optical replacement procedure.
SOURCE: When I put a Wii or Gamecube disc into my Wii Console it says...
This message indicates that your Wii console will need to be repaired.
