Question about Heavy Machinery
Steering problem with 1986 case 580e backhoe - Heavy Machinery
    New Friend:
  • 23 Answers
Could you be more specific in the syndrome?
Posted on Oct 23, 2019
Specs on head bolts and order to torque sequence for a 580d case backhoe
http://www.ioffer.com/i/case-580d-loader-backhoe-service-manual-580-d-bonus-162592324
Jun 05, 2015 | Cars & Trucks
Case 580E backhoe. Stopped running right in the middle of working. No sputter, nonthing. I thought I head a small pop when it quit, but no one else did. Now it will start when we use starting fluid, but...
check for fuse in the stop solenoid circuit
assuming it is a diesel engine that would be one thing to cause a sudden stop next would be a fuel air leak
if is a disaster to use easy start in a diesel as they have been known on many occasions to blow the piston through the sump, break cranks or blow the heads off
The reason is simple
diesels compress the air to white heat and then inject fuel at around 15 degrees btdc
by spraying in easy start which is highly volatile , it will self ignite around 95 degrees BTDC as it makes the compressing air highly explosive
Feb 16, 2018 | Miscellaneous
Case 580E 4wd 1984 front wheel bearing.
jack up the front of the tractor and place on jack stands. Remove the cover and drive axle . remove the wheel. treat the hub as a heavy truck rear end assembly as it will be the same principle as to positioning of the bearings and adjustment.
Dec 15, 2013 | Cars & Trucks
Heavy Machinery Logo
81 people viewed this question
Top Heavy Machinery Experts
STEVE
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
