SOURCE: I just purchased a savage .17 HMR with a cabelas
A quick and easy way to bore sight your rifle, if it is bolt action only, or an AR, mount the rifle in a cardboard box with cutouts so it will sit without tipping, remove the bolt and sight down the bore at a target 100 yards away, a mail box, or the corner of a building, make sure the rifle doesn't move, then peek through the scope, it should be seeing the same target your bore is seeing, if not, adjust your scope to it, if it won't travel that far, shim the front with pieces of 35 mm film. then check it again, if you can get it to stay there, it will put your bullet on paper at 100 yards.
