Minolta 1080
C000
Main drive problem
C001
Main drive speed. Too fast or too slow
C004C
Fan motor problem
C004E
Power supply fan problem
C0070
Toner motor drive problem
C0071
Toner motor speed. Too fast or too slow
C010
Drum motor drive problem
C011
Drum motor speed. Too fast or too slow
C0400
Exposure lamp does not turn on or AE sensor problem
C0500
Low fuser temperature during warm-up
C0510
Low fuser temperature after warm-up
C0520
High fuser temperature
C0600
Scan motor drive problem
C0610
Lens motor drive problem
C0620
Mirror motor drive problem
C0990, C0991
Main tray up problem
C0992, C0993
Main tray down problem
C0994
Elevator motor problem
C0996
Main tray shift problem
C0998
Tray shift problem
C0999
Tray shift return problem
C099A, C099b
Shift home problem
C099c
Shift drive motor
C0b10
Auto exposure sensor problem
C0b11
Paper clamp motor
C0b30
Paper aligning motor
C0b31
C0b50
Stapler motor
C0b51
Stapler problem
C0b52
Stapler sensor
C0b60
Sorter bin motor
C0b61-C0b64
Sorter bin movement
C0d00
Duplex rail sensor sensor problems
C0d20
Duplex home sensor
C0d50
Duplex drive motor problem
C0d51
Duplex drive motor speed
C0F10
C0F30
C4100
Exposure lamp stays on
C0F79
Paper empty sensor problem
How do you fix coo main drive problem
Sir/Mam, Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the front cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If this does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sir/mam Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the front cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
I for one have no idea what "the mark of toner" is. Please explain.
I have a minolta 1080. It shows an error C06 00. We changed the motor but the sign remains. What do we do.
