Miscellaneous Logo
B
BARNARD Posted on Sep 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
To replace the inverter on a jvc 55 inch tv - Miscellaneous
RudeRude
Level 3:
Master:
  • Master 526 Answers
  • Posted on Sep 03, 2019
RudeRude
Master
Level 3:
Master:
Answers
526
Questions
0
Helped
138258
Points
1635
Ya don't, either get the tech guy to do or toss it. High voltage capacitators inside
1helpful
3answers
My jvc tv 50 inch wont turn on , the red light is on but when i press it , the jvc logo flashes on screen for a quick second then goes off black screen ,
Usually it is the power board. Try finding a replacement power board it should fix the problem.
I fixed my 55" Samsung with the exact same symptom.
I have a 55 inch JVC tv,today the screen went black but still have sound, also the buttons on the back wont work, but the channel down button turns it on and off? What is wrong with it?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary..
Hi my 55 inch JVC led tv model No LT-55N730 have sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
1helpful
2answers
My 55" LG tv has sound but no picture.
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
2helpful
I have a JVC 55 Inch 3D TV LT55N935 it restarted now it freezes on the JVC screen and does not respond
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
1helpful
LG 55LX6500 55 inch LED TV display gone, but sound works.
1helpful
Turn tv on picture for a secondthen goes black but still sound model number is 55LS4500
How can I fix My Sony Bravia 55" LED TV that has a dark area on the Screen
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
1helpful
The rca tv will not power up 55 inch
Is it a rear projection set? or LCD? If it is a projection set it could be a bad High voltage splitter. Part is about $30 If it is LCD it could be a bad power supply or inverter board. A good tech can replace capacitors in power supply without replacing the board
Top Miscellaneous Experts
H Smith
Level 1 Expert
Robert
vince
Are you a Miscellaneous Expert? Answer questions, earn points and help others
