didnt specify unit -generic answer --remove door and place on flat surface or floor --un screw the inner panel --remove glass retaining clips [if present ] -replace glass --replace panel and then door done one of the videos in link an assist you replace oven door glass Yahoo Video Search Results
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
The panels on the door , specially the glass panels can be removed easily if care is taken to remove the fitting screws. You can use a good cleaner glass cleaner to remove any dirt that has deposited on the frame and glass panels. Once the glass is dry it can be refitted , care taken to use gloves so as to avoid hand impressions .
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it. 1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door. 2 Remove the outer screws , starting from lower side of the panel. 3Removethe
inner screws. Keep all set of screws ordered, and take note of theorder
you remove them. You will follow reverse order in reassembly. 4 the frame will be free now, 5 Remove the external glass panel and leave it in a safe place. 6 Replace the inner glass. 7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
"removed the door from the
oven by releasing clips attached to the door hinge -- very nicely
engineered. Removed about 6 philips head screws to allow the door
assembly to be taken apart for access to the glass. Lifted out the
broken glass, cleaned the inside of the door, installed the new glass,
reassembled the door (a two minute project), and reattached the door to
the oven. Cleaning the inside of the door"
"I removed the oven door by
lifting it off with the hinges. Disassembled the door parts one at time
making sure I remember where I removed the screws until I am able to
get to the broken glass. The most difficult part is making sure that
the insulation strip & the gasket stayed in place after I replaced
the broken glass & doing the reverse process of installing the
parts together. Relatively easy process as long as you remember where
the parts go. When in doubt, I had to refer to the pictorial of the
disassembled door shown on your website."
To replace the door glass do the following: 0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it. 1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door. 2 Remove the outer screws , starting from lower side of the panel. 3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly. 4 the frame will be free now, 5 Remove the external glass panel and leave it in a safe place. 6 Replace the inner glass. 7 Clean outer glass and metal door, re-assemble it and mount it back
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
