Question about Fossil Watches
What size battery does my fossil watch take ES 2203
    Top Expert:
  • Fossil Master
  • 30,872 Answers
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Posted on Aug 29, 2019
Anonymous
SOURCE:
Anonymous
SOURCE: changing battery
Generally, there's a small clip that can be held out of the way with a screw. You may need to hold it back, and tighten the screw in order to insert the battery. It may be enough to hold the clip out of the way.
Posted on Jan 22, 2008
riflemenx
SOURCE: Fossil ES1592
watch press
Posted on Jun 19, 2008
Anonymous
SOURCE: Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Posted on Nov 09, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Fossil watch dead
Get battery out again. Clean (scrape) all the battery related contacts using steel needle or small screwdriver. Make sure the battery is not underpowered. Refit the battery keeping the right polarity and set the watch.
Don't forget to rate, please.
Posted on Jan 26, 2009
Jay
  • 103 Answers
SOURCE: 2 Fossil Watches wont work
fossil watches are very temperamental when it comes to there insides. did you have fossil do the band or someone else? also they sometimes have corrosion from the seals not lasting.
Posted on Aug 04, 2010
Which 3 battery sizes go in fossil BG2131 watch?
Take your Fossil watch to a jeweler who will identify the battery type and may even be persuaded to install replacements. All for a reasonable sum.
May 24, 2018 | Fossil Watches
I have a Fossil ES-9722 wrist watch without a battery. What size battery does it need?
You want to know type, not size. Take the watch to a jeweler who, for a few dollars will replace the battery.
Oct 17, 2016 | Fossil ES Watches
Need watch battery size for a fossil blue watch model number Tl-5073
  • Remove back
  • Find battery mounting. Note for later battery installation
  • Read battery type (not size)
  • Obtain exact battery replacement
  • Remove old battery; install new
  • Check operation
  • install back
  • Set watch
Sep 09, 2016 | Fossil Watches
Battery for fossil eatch es-9112
Take your watch to a jeweler for battery replacement.
Apr 07, 2014 | Fossil Watches
I need setting directions for a fossil watch model ch-2203
Thank you for contacting FixYa.
You should be able to contact Fossil at following link for directions/manual to your watch.
http://www.fossil.com/en_US/shop/customer_care/static/fossil-warrantyRepairs.html
Best wishes. Jewel
Oct 02, 2010 | Fossil Watches
Battary size for fossil blue watch bq8775
Thanks for contacting Fossil.
The only way to know the battery size is to pull out the old one. It might also be in your manual. It might be on the outside of the watch.
If battery is missing, then you will have to measure the cavity and match it against a battery chart.
Best wishes.
Aug 26, 2010 | Fossil AM3784 Wrist Watch
Lost the battery for Fossil ES 8949 could you please tell me what battery I need for replacement
Link
Please refer to above link for the replacement of your Fossil Watch.
Suggest to contact the authorized dealer.
Thank you.
Dec 24, 2009 | Fossil AM3425 Wrist Watch
Two months ago I had the battery replaced buno my Fossil watch ES-1289 has stopped working again.
All I did was take the battery out, rub it between my fingers, and then placed it back in the watch.
The watch has been working ever since.
Nov 18, 2008 | Fossil Watches
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Watches Logo
75 people viewed this question
Top Fossil Watches Experts
Janelle Schoonover
Janelle Schoonover
Ray Murphy
john h
Are you a Fossil Watch Expert? Answer questions, earn points and help others
