What kind of saw is it...how old is it??
Testimonial: "Thought it must have a fuel problem, needed advice just in case it involved more, thx Don"
Husqvarna k760
Hi Chris. I had similar problem on a different saw. A few things to look at. The chain tightness should be fine because you made a few cuts. Your fuel can be contaminated (my problem). Empty out the fuel and clean out the tank and filter if installed. Use fresh gas (yes, in your gas can...make sure it is clean as well). Your carb could be contaminated if your fuel was contaminated. How is your chain oil? Plenty available? Also, check your air filter...could be obstructing your air flow. How old is the spark plug? Remember, they don't last long like the ones in your vehicle. I always replace mine annually...they just don't last. That is about the best I can do. If you still have problems after all of this, I would suggest a carb service...not that expensive and it would really clean out the ports. I hope this helps you Chris!
Thanks Don, think it would be a lot easier and quicker if I stuck it in for a service, even though I have not long bought it, if too pricey, then I will have to do a DIY, thx again, very helpful
Change the bearing
SOURCE: chainsaw cuts out a few seconds running
hi frado
check the fuel lines,make adjustment to the carb,set the T ,check the fuel filter.Inside the carb,at the fuel pump side there is a screen,carefully clean it.Hope theese help.
regards savumihai71
SOURCE: my internet keeps cutting out nad then connecting
It may be your wireless NIC. Have you tried connecting to a different access point?
Testimonial: "fantastic help.. thank you xx"
SOURCE: The engine cuts out after it heats up
This seems to be a common issue as of late, i'd tighten up your idle adjustment so you can run at full throttle with no issue. The tiller's oil should be at the lower lip of the dip stick's access threading while the unit is laying face down (gas tank down). Clean up your carb as well and change your plug/filter, if this doesn't work than you're probably looking at some simple carb adjustments, but the fact it dies after 10 minutes of use makes me think it's running either dirty or too rich.
SOURCE: Briggs & Stratton Modle# 100000 will not stay started.
your engine is only running on the fuel you are pumping in, the carb. is not lifting the fuel on its own, maybe because of water in the bowl or dirty jets. You must take the bowl of and clean it out and depending on the type of carb. it might need a new diaphragm. Stephen.
Testimonial: "very helpful. will follow instructions. Thank you"
SOURCE: CITROEN C2 HDI KEEPS CUTTING OUT WHEN ACCELERATING
i have recently bought a citreon c2 1.4 hdi furio sensodrive, iv had it for a couple of months now but recently in the morning its giving me trouble starting up, as i start it and after a few secs it keeps cuting off, but after a few attempts it bes ok for rest of the day, and also i was concerned about the diesel pre heat light, as it never comes on , and when i rand the dealers who i got the car off they said it dosnt have 1 due to its straight injection, is that true
