The BZ 200 is a 'transformer' ... it converts incoming 120 volt AC to 24 volt DC ....
If you connect dimmer to the power pack, it changes the waveform of incoming voltage, or changes the voltage ... the transformer cannot deliver the correct output voltage.
It's like connecting a cell phone charger to a dimmer ... the charger will not perform as expected.
BZ-200 manual appears following link:
http://waterheatertimer.org/pdf/Legrand-BZ200-120V-AC-to-24V-DC.pdf
SOURCE: 1981 evinrude 115HP outboard - The wire connecting
1) I cleaned the terminal ends and whether or not I mixed the wires up again, I really dont know but I managed to get the motor started.
2) I took the starter motor apart and cleaned the plates which make contact with the brushes, this made quite a difference to the working of the starter motor.
