Https://www.partselect.com/Models/FEQ1442ES1/#Symptoms
click on the wiring link under the
Manuals & Care Guides for FEQ1442ES1
and this will explain how to decipher the flashing lights.
SOURCE: Kenmore dryer won't start
your blowing that many thermal fuses, id replace all the thermostats. (2) come in one kit both on heater box 1 top and one bottom. id also look into your venting, a clogged fo kinked vent is going to overheat the unit and blow all sorts of stuff(not to mantion the potential fire hazard of a bad vent
SOURCE: Thermal limiter stops dryer; replaced multiple times. Dryer dead.
I think you are working on the wrong end. Check the fan and inlet ductwork of the dryer, if the air isn't moving properly, it will not move enough to keep the coils and limiters cool and they will fail after working properly a few times.
SOURCE: Your suggestion to 'press <
there should be a dip switch in the back or a jumper that switches it from C to F.
Pull the t-stat off of the wall and check out the back to see if there is a switch or a jumper to do that.
heatman101
SOURCE: My frigidaire dishwasher is blinking lights and a
Here is a tips that I wrote
that will help to explain why you get the PF Error Code
PF
Error Code for Appliances
heatman101
SOURCE: FRIGIDAIRE MODEL FEQ1442ES1 LIGHTS FLASH THEN DRYER SHUTS OFF
Hi - From what you have described the unit could possibly have a communication problem with the control board. However, if the unit is producing heat but will not complete cycle please confirmed that the door is closing properly. If it is not, the unit could possibly have a defective door switch or cord/wiring. Either, or, could be faulty at this time. I would suggest contacting a professional to move forward accurately since this is not a typical DIY job.
