If i on the breaker its chisel it starts to hammer even though it wasn't contacted to a certain surface just like stones.
SOURCE: cant find chisels for the Central Pneumatic Aire Chipping Hammer.
You need to order that from
Harbor Freight.
Customer Service 1-800-444-3353
9:00am-7:30pm
Monday-Friday
Eastern Time
ITEM 99792-3VGA
SOURCE: stuck chisel
if you have access to a vise I would lock the chisel in it and pull on the release collar and then take a dead blow hammer and "tap" on the drill to try and pull it away from the chisel.
SOURCE: chisel not striking on makita demolition hammer
The o-rings are probably worn out. Take it to a service center and have them diagnose it. It most likely will need a service kit installed.
SOURCE: hilti te 56 combi hammer not working
The gears inside that engage the chisel points to move back and forth are either not alligned properly or are stripped. You'll have to open up the hammer to see what, exactly, is the problem.
SOURCE: chisel will not stay in dewalt demo hammer and falls out. it is a sds max unit
Retainer spring loose or worn , try a stronger spring.
