You might try measuring resistance of the clutch coil. It should be 1.5 to 3 ohms.
Also check continuity of the grounded conductor at the clutch connector. It may be open which would give you 12V reading at the clutch but no energize.
Check the linkage on the deck
If you have voltage at the clutch it pretty much has to come on unless it is burnt up. possibly a bad connection where it plugs into the clutch. or the wires going into the housing of the clutch may have been broken.
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
SOURCE: mower blades will not turn on with pto switch engaged on john deere stx 46
first look for a blown fuse the old clutch may have burn it out the check to see if a safety switch burned out
SOURCE: John Deere SST16 PTO won't engage mower blades
check for power at the clutch if no power check the safety switches and the switch itself
check the wires just as they go into the clutch i have had them break there and have been able to repair the wire
