Robert Bruce Posted on Aug 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i turn off my Panasonic model sa-ak18, it won't stay off. It shuts off for a short time then it comes on again by itself? How can i repair this?
starvin
Level 2:
Novelist:
  • Expert 208 Answers
  • Posted on Aug 23, 2019
 starvin
Expert
Level 2:
Novelist:
Answers
208
Questions
0
Helped
61236
Points
421
Unplug it from the power outlet.
5 Related Answers
Anonymous
  • 152 Answers
  • Posted on Dec 18, 2007
SOURCE: assistant
check your sleep timer settings thats the most comman prob
Anonymous
  • 10 Answers
  • Posted on Apr 05, 2008
SOURCE: panasonic model SA-HT740
Most F61 code failures are caused by a defective output ic.If all speakers are disconnected and F61 still comes up the IC is 100% bad.Needs to be serviced.Not an issue that can be fixed by homeowner.
Anonymous
  • Posted on Aug 19, 2008
SOURCE: Technics SA-GX500
It looks like overheating problem. Dust fills heatsreader of amplifier.
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on May 03, 2009
SOURCE: Sansui tv shuts off by itself after being turned on.
the relay on the power board needs to be replaced; if you feel confident to do this:unplug the tv wait about a 1/2 hour then remove the tv's case carefully look for a small black or, brown box about 1/2" x 1" x 1/2" this relay should have a designation such as Rly 1 printed on the circuit board it must be unsoldered and, removed the numbers on the relay can be entered into a search engine to find a replacement
Anonymous
  • Posted on Nov 11, 2010
SOURCE: my CD Stereo System SA-AK18 turns off itself
My stereo turns off and displays F61. How do i fix it.
Panasonic 5cd mod.# sa-ak18 won't play why
Presuming that other sources work okay and the the cables are connected correctly.....Try a CD Lens cleaner.
If that doesn't work then it's time to open up the unit and manually clean the laser lens. If that still doesn't work then the laser might be dead. Replacement parts may be available. Whether or not you can do this as a DIY repair though is questionable. It depends on your skill.
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
My stereo C918X turns off every time iput the volume up displaying f61
The audio output ic is getting to hot due to bad connections or ic failure. Check the speaker wires for shorts, if okay! semiconductor needs to be replaced.
Need to copy manual for home sterio system sa ak18
Hello
Get into this website, from where you can download the user manual of your stereo system in Adobe Acrobat document. If you feel any difficulty in downloading the manual, send your email address to me by FixYa. I've the manual and I'll send a copy of it to you by return mail. OK
www.usersmanualguide.com/panasonic/cd_stereo.../sa-ak18
My dvd stereo system panasonic model SA DK2 , F61 error,and immediately power down, comes on when turned on and then powers back off. please help
F61 usually means the amp has detected a short.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
6helpful
2answers
What does f61 mean?
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Error f61
my CD Stereo System SA-AK18 turns off itself displaying f61 error, what does it means? how can I fix it, plz help me
2helpful
On display appears f61
ic stk 470-040 is blown.this is the most common error.just get it changed
After about 5 min my system turns itself off
hi the problem your having could be one of a couple of things the first to check is that all the speaker wires a fitted correctly and not come out of socket as a speaker wire shorting could give you the problem your having.
The second and most likely problem is going to be a problem with the amp part of the circuit board usually a blown resistor but in your case as the unit comes on for few minutes then the chances are its just a solder joint failing on the board this causing the unit to trip out as a safety measure to stop it setting on fire.
Check the sub woofer cable is fitted properly as this is the usuall problem with you make and model let me know when you have checked all of this ok
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
