I don't know. [stop - your mower may be under warranty and may qualify for free repairs. check with your owner's manual for a free number to call for information]. before working on it, make sure the battery is removed. consider turning it upside down to inspect the wheel. if there is no physical blockage stopping the wheel from turning, you could try spraying the bolt with WD40 or a few drops of motor oil. if the wheel turns, lubricate it again and do the same to the other wheels. if it does not turn, the wheel will have to be taken off.
SOURCE: What is causing slipping of rear right wheel on
most likely the gears that are inside the wheel hubs.
SOURCE: Rear wheel drive does not push mower when engaged.
remove the rear wheels and check the gears in the wheels- they are plastic and part of the circumfrance on the inside of the wheel. If worn replace wheels.
also check belt- it should be tight with very little play when drive is engaged ( obvioulsy check this with engine off).
SOURCE: Replaced both rear wheels +gears
Sounds like when you replaced the wheels you did something wrong and now they are unleveled.
