Question about Onkyo Audio Players & Recorders
Hi there , we are trying to get sound on our Onkyo amplifier TX-RZ830. It keeps going into auto shutdown. How do we get it off auto standby please?
    New Friend:
  • 3 Answers
Disconnect all speakers and try, if it does the trick then you have a shortened speaker connection, try connecting one by one to find out which one.
Posted on Aug 23, 2019
    Loyalty:
    Visited the website for 30 consecutive days.
  • 130 Answers
See photo.
Hi there , we are  trying to get sound on our Onky - 2783365f-0306-40a7-a154-56687e8b1f9b.jpg
6ya staff
SOURCE:
Anonymous
SOURCE: Onkyo TX-8522 stuck on standby
This is Not a real Fix, However it stops the problem!
Do not plug any power cords into the Receiver.  I have found that using the "switched or unswitched" plugs in the back cause the trouble.
Posted on May 12, 2008
maxchojinech
SOURCE: Onkyo 805 sub hook up problem
I made the same mistake when i hooked my REL sub up to the back of the 805.
The problem is there are 2 connectors on the back of the amp that are labeled as sub out. Look very closely, you will see that there are 2 grouped RCA outs. The RCA out group you are looking for differentiated by groups of "little white dots" all the way to the far right on the back of the amp. Hope this helps.
Posted on Jun 09, 2008
Anonymous
  • 142 Answers
SOURCE: standby button stuck
Hello. Check all of the buttons on your unit to make sure that they are not stuck...you can feel the click they make as you push it then they pop back out as your finger pulls off. Any stuck button will lock up your microprocessor and keep the unit from turning on. All other problems will require a consumer electronics technician to trouble-shoot the turn on circuit. If you know how to use a meter and know how to solder\unsolder and require further assistance you can contact me. Good luck.
barneyluc
Posted on Oct 19, 2008
Anonymous
  • 682 Answers
SOURCE: Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Posted on Apr 09, 2009
ABRsvcs
  • 4234 Answers
SOURCE: receiver does not power on. standby not on either
The standby light should be on. If it is not, then check the main fuse. WIth the unit unplugged, remmove hte top cover and check the fuse by the line cord. If that is ok, then you will need to check the primary winding on the standby transformer. That transformer has a thermal fuse internally located and that sometimes gets blown due to a power surge. If you do not have the equipment to test this, get a detailed estimate from a local servicer. The standby transformer usually costs arounf $25 or so.
Dan
Posted on Apr 26, 2009
Tx-906 hdmi board no video
Hello Michael, I am sorry that you are having an issue. I suggest a reset of the receiver. Press and hold vcr/dvr on the front of the receiver and then on/standby. When the display shows clear let go, the receiver will shut down. Power on and test video. If the reset does not resolve your issue it would need to be serviced. Thank you, Onkyo USA
Nov 12, 2016 | Onkyo Audio Players & Recorders
When I press standby on my onkyo txsr307 it switches off and what will it be
Hi Geoff, is it going completely off and not going in standby? Thank you Onkyo USA
Sep 25, 2016 | Onkyo TX-SR307 A/V Receiver
ONKYO TX-SR307. Problem with volume/sound getting lower. "Setup" does not alter / resolve the issue. Please help
Hi, if this has not been resolved please try the following reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings, Thanks, JT
Mar 02, 2015 | Onkyo Audio Players & Recorders
Sr576 standby light blinking
Most likely, you have DC Offset(a bad amplifier). The unit is shutting down to protect your speaker system, as well as protect the unit from any further damage. If you require more assistance, or would like to inquire about repairing your Onkyo, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Jul 22, 2012 | Onkyo TX-SR576 7 Channels Receiver
I have an onkyo receiver tx-sr603x. I can get
audio amplifier´s damaged need to be replaced
May 25, 2010 | Onkyo TX-SR605 Receiver
Trips and switches off
Hello Fixya customer,
Thank you for your question.
The best way to fully isolate the fault is to disconnect all the speaker wires, and verify that there are no strands of wire shorting between the speaker terminals on the rear of the unit.
Turn the volume all the way down, full CCW, and if it goes into shut down with the STBY light blinking then there is a fault in one of the amplifier's.
Thank you for using Fixya, and if I can be of further assistance please ask.
May 01, 2010 | Onkyo TX-SR706 Receiver
"standby" on Onkyo TX-910
That sounds like an internal problem inside the unit
Jul 18, 2017 | Onkyo TX-910 Receiver
Onkyo amplifier
Is power coming out of transformer at the right voltage. Also may have a power i.c. shorting to ground.Final anp i.c. may have a place to go to ground through a shorted capacitor.
GOOD LUCK
Big Red
Dec 17, 2007 | Onkyo TX-SR674S 7.1 Channel Up-Converting...
41 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
