SOURCE: need Manual for Krups coffeemaker AG E 15 - can't set time
I went to the Krups web site and pulled a copy of the manual for a different model with the same user interface. This solution worked fine. My model (on the baseplate) is AG E 15. The manual that I printed was for a FMF5. Cheers!
SOURCE: krups water level problem
I have the Krups FMF5 Gives a 'low water alarm' when it's full of water. Take a cheap multimeter from Wal-mart find which themal fuse on the heating element doesn't have continuity. Should be two of them on the unit, one on each side of the silver 'U' shaped element, They are covered in a white sleeve, with a metal retainer holding it to the element. They connect to the power wires White one and Black one going to the element. Mine was a SEFUSE rated for 214 degrees C, Less than $2.00 at Radio Shack I replaced it with a 226 degree C rated SEFUSE which is better than removing it entirely. (it is a safety fuse) I reused the old crimps holding it to the wires, Don't know if solder would hold up. Works like a charm.
SOURCE: Krups FMF5 coffeemaker- coffeemaker begins to brew
Check for any blocks in the route of water from the reservoir. And do not try to run the machine several times before the problem is rectified. It may cause further damage.
