(I turned water supply off and ran RO faucet until it stopped)
Put some air into the valve stem, once the tank is empty charge it to 10 psi then turn the water back on. If you get air out of the faucet, the tank is shot.
Thanks. How would I do that?
Simply take the cap off the valve stem, and add air. I'm assuming you don't have an air compressor? You could use a air pump, like you use for a bicycle. If the water is off, and the faucet is open, it doesn't take much effort to get to 10 psi. If your referring to the valve stem, look for a plastic cap on the side of the tank about a 1/4 of the way up from the bottom. It is a cap with a flange built in (not quite like a tire) be sure to put it back on when you are done.
Thank you. SO my tank doesn’t have a valve stem. It has the shut off on the top and that’s it, no stem on the side at all.
HA. Found valve stem. It’s on the bottom
SOURCE: Water filter system leaks at tap
The line from the faucet to the drain was plugged. I cleared the line and the system is working well.
SOURCE: Culligan RO sstem has recently stopped producing more that 6 oz
This might be a possible tank pressure issue. This could also be a clogged filter. I would first check the tank pressure by using the following steps
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO System Tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
SOURCE: Rohl 3810 kitchen pullout faucet leaks under the sink
call ROHL at 800.777.9762 and request a new Cartridge. They will ship it at no charge.
There has to be a cap some where on it to put air in the bladder. You don't see a plastic cap anywhere on the tank? I've never seen one that did not have one. It simply looks like a plastic cap with a flange. It is possible it is on the bottom. These Chinese engineers sometimes do less than smart things.
