Without seeing it in person. I would be sure fuel is not restricted by a clogged filter or varnish and debris in carb. Check vent in fuel cap , it must have one. Some engines can have a valve stick when hot, usually the exhaust valve, it will turn over very freely . Then next would be a faulty ignition module/coil.
SOURCE: when mower gets hot it cuts off crank back up run a min cut off
1 of 2 things happening
first change the fuel filter seams that the gas is vapourizing
If that does not fix it replace the engine coil as it heats up it is breaking down in voltage causing the engine to die
SOURCE: suburban stalls while driving
a bad crank sensor can cause this. shuts off while going down road, and will start about 10 min, later with no problems runs fine until it quits again. hope this helps,
SOURCE: walk behind craftsman lawn mower. starts but shuts off
my craftsman 917378490 left front wheel has stopped pulling.
Right front seems ok. Axle is turning on left front from gearbos.
SOURCE: Ford E-350 2001 V-10 gas.
Check your fuel vapor recovery system, your van has unusual set up, and the effect is RAW fuel gets purged, rather than vapor.
The dead giveaway test is does the issue happen on light acceleration? Does it stop if you let off the throttle? Can you accelerate harder and "get past" the issue?
SOURCE: Motor runs for 5-10 min. then starts missing and quits.
I have GT6500 26HP runs for awhile begins miss firing runs on one cylinder, must be running hot ( fuel may be vaporizing ) removed the Hood and it runs fine.
