Any key I push I get the er32, I tried to rotate the key into programming and tried to change a plu price and it took 1220 . and @doesnt work shift to er32 again. So the only one allow me to push a number is that
SOURCE: I cannot change the price for an item on CASIO TE-2400 register
Hi. I'm afraid this is not a 'basic requirement' of a cash register. You are working with a very complicated area of cash registers that only the medium to high end machines can even do. If you are getting stuck already, then you will not be able to work out the more complex batch processing areas of scanning either.
Your dealer should have setup the majority of this for you before you left their store (especially the keyboard layout issue and keysheet for the keyboard), then you would normally receive extensive training if you are going to be making program changes yourself in future.
You will need to learn about the difference between flat PLUs and scanning PLUs, 'Not found PLUs' like you have run into so far, then deletion techniques, PLU status programming, manual entry using OBR method etc. The book is only a guide to what you should have learnt during training. You really need to go back to the dealer and get a training session. They should be able to sort out all of these problems for you. It will take a one on one demo to fully train the ins and outs of full scanning systems.
Mark
SOURCE: Casio TE-2400 PLU programming
Hi. You have been given the wrong instructions. That is why it is now all screwed up. Pricing is dead easy. You have condiments setup because you have set key features in prog 3 mode. It shouldn't be too hard to fix. We'll start with prices: Turn key to Program mode Type the price (no decimal point) Press a PLU (item button) to set the price to. Press SUBTOTAL To remove condiments, you need prog 3 mode. While key is on program, press 3 then SUBTOTAL. The display must change to "P3" Now press 0 (zero) then one of the PLUs that has condiments set. Press SUBTOTAL to finish. It may remove the tax status, so turn back to REG mode and test the PLU. If the tax has gone, then reprogram the tax setting for that PLU. Let me know if you get stuck. Mark
SOURCE: my sharp cash register ER-A550S stop working
The letter H appears in the screen. The register will not respond. Any idea to what the Letter H means?
SOURCE: I'm working with a PCR
Turn the key to PGM mode.
Type the new price without decimal point e.g 500
Press the dept key (item) you want to change.
Press SUBTOTAL
Turn key back to REG and test it.
If anyone needs a Casio PCR-T2100 manual, try here:
http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
