Http://www.deere.com/en_US/ProductCatalog/HO/servlet/servlet/com.deere.u90785.cce.productcatalog.view.servlets.PublicationsSearchServlet?userAction=publicationsSearchResults&entryPoint=other&orderBy=pubType&tM=HO&searchCriteria=e140&language=english&submit=Search
Also, apparently may be manuals for it on sale on ebay.com
SOURCE: JOHN DEERE TRACTOR - MODEL A - SERIAL 642202 CLUTCH REPAIR
Try the John Deere web site, I think they will be able to help. donnyb60
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
SOURCE: need an owners manual for a john deere lawn LT-133
you can go to www.deere.com and then click on residential equipment on the next page click on services and support and then enter your model number you will need your machines serial number to choose which model you have. here you view on online or order a new copy on cd
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
