Both pairing to a tablet and to a Macbook pro fails. It connects and ask me to enter the random passkey shown on the pop up message, followed by the enter key. But when i do so the pairing fails with message that passkey is not identical.
The passkey is default set for all Motorola headsets at 0000. try that. If this works, be sure to rate the solution. Thanks!
SOURCE: BlackBerry won't pair with device anymore via Bluetooth
1. Go to Options/Bluetooth
2. Select device found
3. Select device properties
4. At Trusted select yes
It'll never ask again
SOURCE: Can't find passkey for bluetooth. (0000 won't work)
hey ! you cant give random pass keys..you ll have to provide a pass key to the device to which you are trying to pair with..and that pass key must be entered so that your other device is safe..! so you provide your other device with a pass key ..then try..ok
