How do I get my Casio LW-200 from military time to standard time
I have looked up a ton of things and it says to hold adjust until the seconds start flashing but the seconds aren't what starts flashing. I have clicked every button and tried every possible combination of clicking (I think) and I can not get the 24 hour setting on the top left of the watch. I can't get past the holding adjust step and I don't know what to do. I doubt my watch is the only one that does this but I can't find anything telling me how to fix this in a way that would work my specific issue. I am getting a little tired of having to decipher the military time when I just need to know the time.
Re: how do I get my Casio LW-200 from military time to...
To set time and date, you must in "Time Keeping Mode" (display day, date & time) then press and hold the left-up button until it start flashing. To set press right-down button, to go next setting press left-down button.
To toggle between 12-hour to 24-hour, again, must in "Time Keeping Mode" then press right-down button.
hit mode three times until TUES flashes and the seconds. Hit reset until the hours flash and hit start to change them. The watch goes from AM hours to PM and then back through AM and when it cycles through the PMs for the second time, they will alternate 12/24 hour time.
If you mean switch from 12h to 24h and vv,all you have to do is to press the "ADJUST" button until digits on the display blink.Then press the "MODE" button until 12H blinking appears.Press the "START-STOP" button to switch to 24H.When finished press the "ADJUST" button again.
From the main time display, hold down the adjust button until it beeps and your time zone is flashing on the bottom of the display. Then press adjust again. 12H or 24H will be flashing at the bottome. Use the receive button to cycle the mode. When it's what you want, press adjust.
Thank you for contacting FixYA.<br />
<div style="BORDER-BOTTOM: medium none; TEXT-ALIGN: left; BORDER-LEFT: medium none; BACKGROUND-COLOR: transparent; COLOR: #000000; OVERFLOW: hidden; BORDER-TOP: medium none; BORDER-RIGHT: medium none; TEXT-DECORATION: none">
<li id="jsArticleStep1" itxtvisited="1">
Examine your watch. Attempt to find its "Mode" button; nearly every digital watch has one. The various modes might include "Date," "Alarm" and "Stopwatch" among others. Repeatedly press "Mode" to cycle through the modes available on your watch until you have it in the mode that displays the current time.<br /></li></div>
<li id="jsArticleStep2" itxtvisited="1">
Locate the button that allows you to adjust the settings on your watch; this button could be labeled "Set" or "Adjust." Once you've found this button, press it in and hold it. After a few moments, the time display should begin to flash.<br /></li>
<li id="jsArticleStep3" itxtvisited="1">
Select either minutes or hours as the aspect of the time you'd like to adjust. Press the "Mode" key to cycle through your options; each element should begin to flash as it's selected.<br /></li>
<li id="jsArticleStep4" itxtvisited="1">
Press a button to adjust the time element you've selected; the button for doing this will vary from watch to watch. If there are up and down arrows on your watch, use them to increase or decrease the number. A button labeled as another function could serve this purpose too; trying pressing the various buttons on your watch to discover the correct one to adjust the time.<br /></li>
<li id="jsArticleStep5" itxtvisited="1">
5
Move on to the next element you want to adjust, such as minutes or the date, by pressing the "Mode" display.<br /></li>
<li id="jsArticleStep6" itxtvisited="1">
6
Press the "Set" button to finalize the new time on your watch. You'll know that the time has been set when the numbers stop flashing.<br /></li>
<br />
For more Casio info go to:<br />
http://www.casio.com/support/<br />Best regards.
Depress the recessed 'Adjust' button (top left side) which will get the time setting flashing. Then depress the button on the lower right side once to get to the 24 hour time option. You will then have manually enter the time in that format. Once set, then depress the rescessed 'Adjust' button again.
Light button is A Mode button is B Start button is C Reset button is D
Standard Time Adjustment: 1) To set time, date, etc. press button B three times (assuming you start in standard time display mode) 2) Press button D until the area you'd like to change is flashing. (i.e.: minutes, date, day, etc.) 3) Press button C to change. Press once for one unit increment of change. Hold for 3 seconds for speedy advance. 4) Press D again until the next area you'd like to change is flashing. 5) At completion of changes press Button B to resume standard time display mode.
Dear gap.com Customer,
Thank you for your email regarding the Sporty Printed Watch user instructions. Please accept our apologies that no directions were received with your order.
The instructions are as follows:
Button Functions:
A. Light B. Mode C. Start D. Reset
1. To set the time, press the Mode button three times (The seconds and the word Tuesday should start flashing).
2. If the seconds position shows less than 30 seconds, pressing the Start button will reset the seconds to 00. If the seconds position shows more than 30 seconds, pressing the Start button will reset the seconds to 00 and the minutes will increase by 1.
3. Press the Reset button until the area you want to change starts flashing (i.e., second, minute, hour, day, month, and weekend. Press Start button once for per unit increment, press and hold for 3 seconds for speedy advance.
4. At completion, press Mode button to resume standard time display.
To reset the Alarm:
Press the B: Mode button until you reach the alarm.
Press the D: Restart button.
Press the C: Restart button to get back to the time
