SOURCE: Nextra Hoover Fridge Freezer, Fridge not cold enough.
I would turn the thermostat up towards number 4.
SOURCE: Hello, I have a fridge/freezer hoover
you have a defrost issue, while not familiar with hoover, normally there is a defrost timer, a defrost heater and a defrost thermostat, one of these three things are not operating. (may be more than one )
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
SOURCE: the fridge part of my fridge freezer keeps freezing everything,
Hello
I have the same problem and have talked to the manufacturer. They said to turn off the appliance for 24 hours then it should be good as new when you switch it back on. Obviously you'll have to find somewhere for your freezer contents. I'm going to try this myself tonight.
Fridge Reboot!
SOURCE: Hoover Fridge Freezer thermostat (model HFA290)
Try www.fridgeshop.net and look at "Candy Hoover Problem"
