Probably. You can use a 1913 rail with a forward incline to get more elevation. How far are you trying to shoot? 450 yards is further than most hunters will try to take game because of terminal ballistics and ability to precisely place the shot for a clean, humane kill. Target shooting is still getting close to out of range - bullet drop on a 300 win mag 180 grainer is pretty severe - at 500 yards it is falling 55 inches, and it gets progressively worse with heavier bullets and longer ranges.
At less than 300 yards this caliber will take down any large game animal in North America. You have chosen a very effective caliber, but all calibers have limitations.
SOURCE: is there a way to lower my turret after i've found
No. The turret is what it is. If you want to re-set the turret to zero so that it is easy to return to for a specific distance, there should be a setscrew you can loosen, adjust the turret to zero, then re-tighten to lock it in place. If you are simply trying to lower the turret, you need to purchase a scope without target turrets.
SOURCE: Elevation turret stripped out. Entire turrent
ok,,,you have strong fingers then????
try a drop of supper glue on the striped out turret thred,,,as the scope is a right off anyhow you have nothing to loose do you?
SOURCE: top turret sticks
Remove numbered turret, check stem for dirt or grim...if it turns hard send it to Premeir under the warranty or email scopeshooter AT yahoo DOT com
SOURCE: my bsa sweet 17 6-18
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Make small adjustments tap the scope with a screwdriver handle to give it a shock, not to hard to help move the cross hairs and try to bore sight first. Hope this helps Fix ya up.
